02-13-2024 02:44 PM
Node Reference Issue: In my Java code, methods for retrieving Node References are working correctly in my local testing environment. However, when deployed to Kubernetes, these methods return NULL. XPath Issue: The Node Browser fails to find the Company Home node using XPath searches in the Kubernetes environment.
Environment:
Alfresco 7.4 Solr6 Kubernetes
Troubleshooting Steps Taken:
Solr Reindex: I've fully reindexed the Solr search container. Local Verification: Confirmed functionality in a local test environment. Basic Searches: General searches seem to return files as expected.
Logs show this:
2024-02-13T19:32:00,150 [] ERROR [quartz.core.JobRunShell] [DefaultScheduler_Worker-4] Job jobGroup.filingScheduledActionCronJob threw an unhandled Exception: java.lang.NullPointerException: Cannot invoke "org.alfresco.service.cmr.repository.NodeRef.getStoreRef()" because "nodeRef" is null
Methods
private NodeRef getNodeByPath(final String nodePath) { final String escNodePath = nodePath.replace(" ", "_x0020_"); StoreRef storeRef = new StoreRef(StoreRef.PROTOCOL_WORKSPACE, "SpacesStore"); final String query = "PATH:\"" + escNodePath + "\""; ResultSet rs = serviceRegistry.getSearchService().query(storeRef, SearchService.LANGUAGE_LUCENE, query); NodeRef nodeRef = null; try { if (rs.length() == 0) { return null; } nodeRef = rs.getNodeRef(0); return nodeRef; } finally { rs.close(); } }
public NodeRef getCompanyHome() { NodeRef nodeRef = null; ResultSet rs = serviceRegistry.getSearchService().query( new StoreRef(StoreRef.PROTOCOL_WORKSPACE, "SpacesStore"), SearchService.LANGUAGE_XPATH, "/app:company_home"); try { if (rs.length() == 0) { throw new AlfrescoRuntimeException("Didn't find Company Home"); } nodeRef = rs.getNodeRef(0); } finally { rs.close(); } return nodeRef; }
Questions:
What are common causes for Node Reference retrieval failures specifically within a Kubernetes deployment of Alfresco? Could there be a configuration issue (Kubernetes or Alfresco) that's preventing correct XPath queries from working?
02-20-2024 08:00 AM
For XPath lookups like /app:company_home there is the separate selectNodes-method in the SearchService API. Especially paths that should be guaranteed to exist / consistent should be resolved that way. The primary difference from the query method is that query always uses the index for XPath lookups, while selectNodes will use actual DB-based hierarchy traversals, unless you explicitly use full text search selectors in the XPath expression - and even then the evaluation will only use index-based sub-queries for those selectors individually.
The Lucene language should NOT be used at all anymore. Only FTS and CMIS are fully supported for index-based queries.
Other than these basic remarks, I have not run into any specific issues with index-based queries (even including paths like this) in k8s-based Alfresco deployments. Without additional information (like a screenshot from the Company Home node in Node Browser to check its actual primary path) or low-level inspection of the index state, it is hard to guess what might be the cause in your constellation.
