10-15-2018 08:03 AM
I need to include Activiti 6 to my maven project dependencies.
The link provided in the documentation is not correct :
To include the Activiti jar and its dependent libraries, we advise using Maven (or Ivy), as it simplifies dependency management on both our and your side a lot. Follow the instructions at http://www.activiti.org/community.html#maven.repository to include the necessary jars in your environment.
All I get when following the link is some generated Lorem ipsum...
Can you fix that or provide the instructions ?
Thanks a lot.
11-09-2018 01:53 PM
Had the same question, but found the info using the quick start guide: Quick Start Guide | Activiti
