01-20-2017 08:43 AM
Issue - At step 3, Subflow is not getting called in spite of configuration. Please provide any pointers. I do not want to call this child flow from parent flow like below :
01-23-2017 01:22 PM
Hi Sushant, I tried what I had proposed and found it didnt work, so I checked the Activiti defect list.
Seems this is a known (unresolved) issue:
Issue Navigator - ACTIVITI-286 - Activiti: Event sub process not triggered with start signal thrown
I suggest you vote up this issue so we can get it resolved.
Sorry,
Greg
01-27-2017 12:38 PM
Hey Sushant,
I am still trying to work out why the Signal is not being picked up.
But since you are calling the signal task from a Listener, I found a work around.
Rather than using a signal start event. Just use a regular start event.
Then, instead of sending the signal, simply start the sub process from the runtimeService using startProcessInstanceByKeyAndTenantId().
I have attached an updated project with the work around implemented.
Agreed, I dont like it and we need to work out why signals are not working in this scenario, but it shoudl get you moving.
Greg
bp3
01-27-2017 12:54 PM
Sushant, I spoke too soon.
The solution is actually very simple and is because it appears you are using Enterprise Edition rather than community edition.
You cannot call runtimeService.signalEventReceived() to trigger a signal start even in Enterprise edition UNLESS the process was deployed without a tenant id. By default, all deployments will include a tenant ID and the signalEventReceived includes the tenant ID in the query to locate subscriptions.
SO, ALL YOU NEED TO DO IS CHANGE YOUR RUNTIMESERVICE() CALL TO :
runtimeService.signalEventReceivedWithTenantId("EMAIL_SUPPORT_SIGNAL", "tenant_1");
Obviously if you are part of a different tenant, you would include that id.
I tested this and it worked immediately.
Greg
bp3
01-27-2017 08:56 PM
Thanks Greg, I got it working. Much Appreciated.
