09-27-2017 10:40 AM
10-10-2017 06:35 PM
10-09-2017 04:52 PM
I have the same problem:I'm using:- windows 10 64bits
- Alfresco community 5.2problem link:2017-10-09 11:04:20,260 INFO [org.alfresco.repo.admin] [localhost-startStop-1] - Pastebin.com
10-10-2017 03:16 PM
I am not sure if that can be the problem, but you are using an unsupported Windows version.
Check what you should be using here Supported Platforms | Alfresco Documentation
About the problem, one idea would be to install ImageMagick using the official installer, and then make the changes in the alfresco-global.properties in order to have Alfresco using this manually installed instance instead of the one Alfresco installs.
Other than that, you should be searching for the error in the log:
[localhost-startStop-1] ImageMagickContentTransformerWorker not available: 09090036 Failed to perform ImageMagick transformation:
Execution result:
os: Windows 10
command: C:\alfresco-community\imagemagick\convert.exe C:\ALFRES~1\tomcat\temp\Alfresco\ImageMagickContentTransformerWorker_init_source_2535584417039233690.gif -strip -quiet C:\ALFRES~1\tomcat\temp\Alfresco\ImageMagickContentTransformerWorker_init_target_8877265038482905492.png
succeeded: false
exit code: 1
out:
err: convert.exe: RegistryKeyLookupFailed `CoderModulesPath' @ error/module.c/GetMagickModulePath/670.
convert.exe: no decode delegate for this image format `GIF' @ error/constitute.c/ReadImage/509.
convert.exe: no images defined `C:\ALFRES~1\tomcat\tem
This is what you have to fix.
10-10-2017 04:37 PM
Thanks, it works perfectly.
10-10-2017 04:40 PM
Which option?
Using a supported OS or installing ImageMagick?
10-10-2017 06:35 PM
07-19-2018 05:10 AM
This is also worked for me.
