04-29-2020 07:49 PM
Hi everybody!
I was talking with @EddieMay on other thread, wich was really helpful
What Im facing now is that I dont know how to create or generate the PK, alias and password for e-sign
I've installed pdf toolkit 1.4.0 both amp and amp_share file
The option for signing the doc appears, but it asks me for a key, a alias and a password, and I have no clue where to begin or how 😕
Any help will be much appreciated!
04-30-2020 08:04 PM
Many thanks Angel, will give it a shot tomorrow.
I'll let you know how it goes.
Regards
05-01-2020 09:50 AM
Hello @angelborroy happy labor day!!![]()
I believe i got it working.
I could sign a PDF with Autofirma with my key stored on local.key (a dir I chosen), but I did this in my pc, locally.
If i want to drop a PDF to Alfresco and hit the "Sign Document" i don't see the options I see in AutoFirma
Supouse I drag an electronic bill that needs to be signed, I it sign pdf an this appears
Is there a way to sign inside Alfresco? Or as Im as and Administrator I cant see the chocie?
05-04-2020 08:10 AM
Hi @angelborroy
What I posted below is it ok? is there a way to sign a document inside Alfresco as shown in the picture i put above?
Whe hit the button, those are the options I have, and it keeps on loading like waiting for someting.
The doc has already been signed with AutoFirma, but inside Alfresco, I can not make it work
05-04-2020 08:14 AM
I don't know what you mean...
Did you see this video?
https://www.youtube.com/watch?v=Ho8gKwAyfLE
Did you read project documentation in order to understand the different configuration options?
https://github.com/keensoft/alfresco-esign-cert#configuration
05-04-2020 08:27 AM
Yes, I've seen the video and now realized I dont have those files on global.properties.
The problem is when i hit the sign pdf document inside Alfresco, it keeps loading and loading. Could that be the readon
It wont allow me to move forward as it keeps loading
There's no advertisement, just keeps loading
05-04-2020 09:05 AM
@angelborroyI'll put step by step what i've done so far so you can get the whole picture (I will write in spanish, if it's need to be modified or translatded, no problem)
1- Instalacion Alfresco 5.2 en Ubuntu 18.04 en VirtualBox
2- Copia de AMP y APMP_share 1.7.2 en sus dirctorios
3- Instalacion cliente AutoFirma en pc local
4- Generacion de la cclave con Toolkit
5- Copiar y pegar los parametros correspondientes en alfresco-global.properties
6- Puedo firmar un documento localemente en Windows con AutoFirma y mi certificado
EL problema es que cuando quiero firmar con el boton "firmar pdf" se queda cargando esperando el componente de firma y el aviso de seguridad, y eso es lo que no aparece.
A esto me refiero:
Espero se haya entendido donde esta la traba!
Muchas gracias.-
05-04-2020 10:03 AM
Try browser Debugger Console to find the problem.
05-04-2020 10:24 AM
This is what I see
But how is this related with signing the document?
05-04-2020 10:30 AM
The application is being fired by using a local protocol. You need to disable CORS in order to allow the application to be launched from the browser.
05-04-2020 10:40 AM
I've been reading in stackoverflow and other forums and see no way to disabl CORS in Firefox (the browser i user in th VM)
Is there a flag or something to disable it?
