How to find how many folders and documents are present in a site?
madhu_sudireddy
Can someone please help with this?
11 REPLIES 11
The result of document count using the webscript you have sent me is showing max 1000 counts only, is there any way to get the correct count(i.e more than 1000).
The sites with under 1000 document is showing correct count.
cesarista
World-Class Innovator
Hi:
Just put in Alfresco Share Search. For documents:
SITE:"shortsitename" and TYPE:"cm:content"
For folders:
SITE:"shortsitename" and TYPE:"cm:folder"
The number of documents or folders is shown in the first page of the results of the search. You can use only TYPE: if you select SITE context in Alfresco Search or selecting site facet.
You can use REST API too:
https://www.zylk.net/es/web-2-0/blog/-/blogs/listing-thousands-of-noderefs-with-alfresco-rest-api
Kind regards.
--C.
