How to determine the property required for filing: path in smart folders tutorial
therealkemmett
The smart folders tutorial includes an example of using the filing: path property (see Smart Folder Template syntax | Alfresco Documentation ). Specifically it mentions the path can be an existing folder location.
Can someone share some examples of different folder paths please, or where I can locate more information? I would like to drag and drop a file into "General" and have it filed in "Approved"
My current structure is:
Documents
- Approved
- Archived
- Incoming
 - - General (a smart folder)
Chris
cesarista
World-Class Innovator
You may find an example here:
smartfolders/tutorial at master · vhemmert/smartfolders · GitHub
Hope this helps.
Regards.
--C.
Thanks Cesar. I have seen these tutorial files previously; however these don't provide examples I can follow that give me an understanding of folder paths.
Could you advise how I can find out the path to a folder, for example the "Approved" folder in my above example? I'm hoping to have users drop new files into a folder (which will attach some properties), and use a filing action to have those files stored in a different folder.
