03-28-2017 09:20 PM
I have a web-app using activiti engine in a mission critical app and process central to company's core business process. It has been running since 2012. Now, it is showing signs of distress under load. As there can be only one engine, how can it be used to serve multiple requests simultaneously? Please, throw some ideas.
04-03-2017 11:07 AM
"As there can be only one engine" - Is there a particular reason for this? Generally the way you scale activiti based applications is through horizontal scaling.
04-03-2017 11:07 AM
04-04-2017 03:17 AM
Hiplehal _
Yes, like Ciju said, it is interesting to know why you are restricting yourself to 1 Activiti engine?
Have you looked at these articles/documentations?
- The Activiti Performance Showdown 2015 | Small steps with big feet
- Multi-node cluster setup: Alfresco Activiti
Thong Huynh
