06-08-2021 02:04 PM
I'm investigating if an upgrade of my Community 5.2 build to Community 7.0 is possible (easy?).
I want to try and install it locally on my Centos/7 machine.
I read that Alfresco Community Edition 7.0 is available as a distribution zip file for manual installation, or it can be installed using an Ansible playbook (Linux only) for non-containerized environments.
I downloaded the Ansible zip but the procedure necessary to obtain a NEXUS_USERNAME/PASSWORD so I can run the ansible play but the instructions do not detail how to obtain a login/password.
Any Help/Guidance on getting the needed credentials to install Community7 via ansible would be appreciated.
06-09-2021 04:35 PM
Seems like you are using enterprise version package of ansible to install community if i am not wrong. Check your xx-extra-vars.yml to make sure edition value is community and all the dowload urls are pointing to community repo.
Trying downloading the ansible package from here: https://download.alfresco.com/cloudfront/release/community/alfresco-ansible-deployment/alfresco-ansi...
For more detailed info refer:
https://docs.alfresco.com/content-services/community/install/ansible/
Notice in documentation for enterprise command is:
ansible-playbook playbooks/acs.yml -i inventory_local.yml
For community version command is:
ansible-playbook playbooks/acs.yml -i inventory_local.yml -e "@community-extra-vars.yml"
06-09-2021 06:34 AM
Hi! I've never used ansible but searching on Alfresco docs I've found this post (maybe it can helps you?).
In a point of view of perform a migration from Alfresco 5.2 to 7, it's possible. You can check here how is the process. If it's your first time: i'll suggest you first do it with Alfresco 5.2 vanilla in your local machine, just to practice the process. Document the process. Then, make a backup of Alfresco 5.2 and try in your local again. And at the end, try in your servers.
Cheers,
Cristina.
06-09-2021 03:47 PM
Thanks cristinamr,
Yes I read that. It assumes you have ACS7 installed so you can then modify the *.properties files.
The issue is the ansible install requires NEXUS login Credentials in order to download alfresco-content-services-distribution-7.0.0.zip
The Link Ansible is trying to download from is :
https://artifacts.alfresco.com/nexus/service/local/repositories/enterprise-releases/content/org/alfr...
It's extremly frustrating when an install document tells me to enter a nexus username & password but does not tell you how to request one.
TASK [../roles/transformers : Remove from content services] *************************************************************************************************************************
ok: [transformers_1]
TASK [../roles/transformers : Download alfresco-transform-core-aio-boot-2.3.10.jar] *************************************************************************************************
fatal: [transformers_1]: FAILED! => {"msg": "An unhandled exception occurred while templating '{u'acs_zip_sha1_checksum': u\"{{ lookup('url', '{{ nexus_repository.enterprise_releases }}org/alfresco/alfresco-content-services-distribution/{{ acs.version }}/alfresco-content-services-distribution-{{ acs.version }}.zip.sha1', username=lookup('env', 'NEXUS_USERNAME'), password=lookup('env', 'NEXUS_PASSWORD')) }}\", u'adw_zip_sha1_checksum': u\"{{ lookup('url', '{{ nexus_repository.enterprise_releases }}/org/alfresco/alfresco-digital-workspace/{{ adw.version }}/alfresco-digital-workspace-{{ adw.version }}.zip.sha1', username=lookup('env', 'NEXUS_USERNAME'), password=lookup('env', 'NEXUS_PASSWORD')) }}\", u'acs_zip_url': u'{{ nexus_repository.enterprise_releases }}org/alfresco/alfresco-content-services-distribution/{{ acs.version }}/alfresco-content-services-distribution-{{ acs.version }}.zip', u'transform_jar_sha1_checksum': u\"{{ lookup('url', '{{ nexus_repository.releases }}/org/alfresco/alfresco-transform-core-aio-boot/{{ transform.version }}/alfresco-transform-core-aio-boot-{{ transform.version }}.jar.sha1', username=lookup('env', 'NEXUS_USERNAME'), password=lookup('env', 'NEXUS_PASSWORD')) }}\", u'trouter_jar_url': u'{{ nexus_repository.enterprise_releases }}/org/alfresco/alfresco-transform-router/{{ trouter.version }}/alfresco-transform-router-{{ trouter.version }}.jar', u'search_zip_url': u'{{ nexus_repository.releases }}/org/alfresco/alfresco-search-services/{{ search.version }}/alfresco-search-services-{{ search.version }}.zip', u'sfs_jar_url': u'{{ nexus_repository.enterprise_releases }}/org/alfresco/alfresco-shared-file-store-controller/{{ sfs.version }}/alfresco-shared-file-store-controller-{{ sfs.version }}.jar', u'search_zip_sha1_checksum': u\"{{ lookup('url', '{{ nexus_repository.releases }}/org/alfresco/alfresco-search-services/{{ search.version }}/alfresco-search-services-{{ search.version }}.zip.sha1', username=lookup('env', 'NEXUS_USERNAME'), password=lookup('env', 'NEXUS_PASSWORD')) }}\", u'sync_zip_url': u'https://artifacts.alfresco.com/nexus/content/groups/private/org/alfresco/services/sync/sync-dist-6.x/{{ sync.version }}/sync-dist-6.x-{{ sync.version }}.zip', u'trouter_jar_sha1_checksum': u\"{{ lookup('url', '{{ nexus_repository.enterprise_releases }}/org/alfresco/alfresco-transform-router/{{ trouter.version }}/alfresco-transform-router-{{ trouter.version }}.jar.sha1', username=lookup('env', 'NEXUS_USERNAME'), password=lookup('env', 'NEXUS_PASSWORD')) }}\", u'sfs_jar_sha1_checksum': u\"{{ lookup('url', '{{ nexus_repository.enterprise_releases }}/org/alfresco/alfresco-shared-file-store-controller/{{ sfs.version }}/alfresco-shared-file-store-controller-{{ sfs.version }}.jar.sha1', username=lookup('env', 'NEXUS_USERNAME'), password=lookup('env', 'NEXUS_PASSWORD')) }}\", u'sync_zip_sha1_checksum': u\"{{ lookup('url', 'https://artifacts.alfresco.com/nexus/content/groups/private/org/alfresco/services/sync/sync-dist-6.x/{{ sync.version }}/sync-dist-6.x-{{ sync.version }}.zip.sha1', username=lookup('env', 'NEXUS_USERNAME'), password=lookup('env', 'NEXUS_PASSWORD')) }}\", u'transform_jar_url': u'{{ nexus_repository.releases }}/org/alfresco/alfresco-transform-core-aio-boot/{{ transform.version }}/alfresco-transform-core-aio-boot-{{ transform.version }}.jar', u'adw_zip_url': u'{{ nexus_repository.enterprise_releases }}/org/alfresco/alfresco-digital-workspace/{{ adw.version }}/alfresco-digital-workspace-{{ adw.version }}.zip'}'. Error was a <class 'ansible.errors.AnsibleError'>, original message: An unhandled exception occurred while running the lookup plugin 'url'. Error was a <class 'ansible.errors.AnsibleError'>, original message: Received HTTP error for https://artifacts.alfresco.com/nexus/service/local/repositories/enterprise-releases/content/org/alfresco/alfresco-content-services-distribution/7.0.0/alfresco-content-services-distribution-7.0.0.zip.sha1 : HTTP Error 401: Unauthorized"}
PLAY RECAP **************************************************************************************************************************************************************************
activemq_1 : ok=23 changed=3 unreachable=0 failed=0 skipped=9 rescued=0 ignored=0
database_1 : ok=19 changed=3 unreachable=0 failed=0 skipped=3 rescued=0 ignored=0
transformers_1 : ok=19 changed=0 unreachable=0 failed=1 skipped=15 rescued=0 ignored=0
06-09-2021 04:35 PM
06-10-2021 02:26 PM
Thanks, that helps! Migrating from 5.x to 7 seams to be pretty difficult.
I mis the days of just copying over my alf_data dir...
PS. We're trying to get a Quote for the Enterprise edition + Support but I guess everyone is pretty busy at Alfresco...
06-10-2021 03:53 PM
Glad to hear that, good luck.
06-16-2021 06:23 AM
Thank you for accepting the solution - helpful to other users.
Cheers,
