02-21-2018 03:03 AM
hello, i have a problem with activiti-rest, when i configure my database postgresql in db.proprietes, the creation of tables is done automatically in the public shemas, i want to change shema how i do to give it my own shema
02-21-2018 12:33 PM
Hi Yasmine,
If you're using postgreSQL JDBC driver 9.4 or above, you can use the jdbc url param "currentSchema"
datasource.url=jdbc:smileytongue:ostgresql://localhost:5432/activitiapp?currentSchema=someotherschema
if using previous versions I have read that you can use the "search-path" param instead but it seems undocumented.
02-22-2018 04:33 AM
thank you i have this configuration how can i modifie it
db=postgres
jdbc.driver=org.postgresql.Driver
jdbc.url=jdbc
jdbc.username=postgres
jdbc.password=postgres
02-22-2018 04:47 AM
The normal activiti property for activiti should be datasource.url...not sure why you use someting different (I guess you're integrating activiti in another project...?)
Anyway... try to change:
jdbc.url=jdbc:smileytongue:ostgresql://localhost:5432/activiti
to:
jdbc.url=jdbc:smileytongue:ostgresql://localhost:5432/activiti?currentSchema=someotherschema
As stated before "currentSchema" works only for 9.4 postgres jdbc driver and above. MAke sure you have the right version.
