Alfresco running in read-only mode
ebrenes
Hello
I got this error
Alfresco has detected a manual change within the user tracking database, the system has now been switched to run in a read-only mode. Please contact Alfresco Support for further assistance, at https://support.alfresco.com/.
any idea on how to revert this and have the system running again in "write mode".
Note: it is not a license issue.
Erick Brenes.
ebrenes
In my case I was running a cluster architecture and one of the nodes had a wrong hostname, the issue got solved after changing the hostname to its correct value.
This is not related to Alfresco. It is an OS/Linux issue.
12 REPLIES 12
kaynezhang
World-Class Innovator
How did you install your aflresco 6.0.2-ga? did you do it by a clean install or just upgrading?
It seems some bootstrap operations set it to read-only mode to do some backgroud work.
nila
Thank you for your response. Actually it is a clean installation. About the bootstrapping:  How can I debug this?
Cheers.
kaynezhang
Did you install alfresco using docer? did your hardware meet the minimal requirements
https://docs.alfresco.com/6.0/tasks/deploy-docker-compose.html
