09-09-2020 12:14 PM
Could anyone provide an example of an ACS (latest version if possible) docker-compose, and related Dockerfiles, using an external DB and external volumes?
Thanks in advance
Regards
09-15-2020 03:48 AM
Hope this helps:
09-09-2020 12:24 PM
I guess that could help:
https://github.com/Alfresco/alfresco-docker-installer
09-10-2020 02:58 AM
Thanks for the reponse, Angel.
Volumes used in the provided link just applies to postgres and solr, what I need is to set an external (not bind mount) volume for the alfresco repo, which in V6.2.2 uses a "shared file store" in this manner:
services:
alfresco:
image: alfresco/alfresco-content-repository:6.2.2-RC1
mem_limit: 1700m
environment:
JAVA_OPTS: "
-Ddb.driver=org.postgresql.Driver
-Ddb.username=alfresco
-Ddb.password=alfresco
-Ddb.url=jdbc
ostgresql://postgres:5432/alfresco
-Dsolr.host=solr6
-Dsolr.port=8983
-Dsolr.secureComms=none
-Dsolr.base.url=/solr
-Dindex.subsystem.name=solr6
-Dshare.host=127.0.0.1
-Dshare.port=8080
-Dalfresco.host=localhost
-Dalfresco.port=8080
-Daos.baseUrlOverwrite=http://localhost:8080/alfresco/aos
-Dmessaging.broker.url=\"failover
nio://activemq:61616)?timeout=3000&jms.useCompression=true\"
-Ddeployment.method=DOCKER_COMPOSE
-Dtransform.service.enabled=true
-Dtransform.service.url=http://transform-router:8095
-Dsfs.url=http://shared-file-store:8099/
-DlocalTransform.core-aio.url=http://transform-core-aio:8090/
-Dalfresco-pdf-renderer.url=http://transform-core-aio:8090/
-Djodconverter.url=http://transform-core-aio:8090/
-Dimg.url=http://transform-core-aio:8090/
-Dtika.url=http://transform-core-aio:8090/
-Dtransform.misc.url=http://transform-core-aio:8090/
-Dcsrf.filter.enabled=false
-Ddsync.service.uris=http://localhost:9090/alfresco
-DtrialUid=id5487903
-Xms1500m
-Xmx1500m
shared-file-store:
image: alfresco/alfresco-shared-file-store:0.7.0
mem_limit: 512m
environment:
JAVA_OPTS: " -Xms256m -Xmx512m"
scheduler.content.age.millis: 86400000
scheduler.cleanup.interval: 86400000
ports:
- 8099:8099
volumes:
- shared-file-store-volume:/tmp/Alfresco/sfs
volumes:
driver_opts:
type: tmpfs
device: tmpfs
On the other hand, I need to use an external, Oracle DB.
09-10-2020 12:17 PM
services:
alfresco:
mem_limit: 1700m
environment:
JAVA_OPTS: "
-Ddb.driver=oracle.jdbc.driver.OracleDriver
-Ddb.url=jdbc:oracle:thin:@/ip:1521/udp
-Dsolr.host=solr6
-Dsolr.port=8983
-Dshare.port=8080
-Dmessaging.broker.url=\"failovernio://activemq:61616)?timeout=3000&jms.useCompression=true\"
-Xms1500m
-Xmx1500m
volumes:
- /your data path:/usr/local/tomcat/alf_data
09-10-2020 12:34 PM
Thanks for your answer.
What about this?
Won't be alfresco repo using the shared file store?
09-10-2020 11:11 PM
It is used for asynchronously content transformation(also text extraction for full text search).
ACS community edition dose not use this property now.
09-11-2020 03:01 AM
Thanks for the clarification.
I was finally able to run ACS through the next docker-compose, based on the template provided by Alfresco from the docs site (https://www.alfresco.com/platform/content-services-ecm/trial/download😞
version: "2"
services:
alfresco:
image: alfresco/alfresco-content-repository:6.2.2-RC1-Oracle
build:
context: ./alfresco
dockerfile: Dockerfile
mem_limit: 1700m
environment:
JAVA_OPTS: "
-Ddb.driver=oracle.jdbc.OracleDriver
-Ddb.username=<db_user>
-Ddb.password=<passw>
-Ddb.url=jdbc
racle:thin:@<db_server>:<db_port>:<db_instance>
-Dsolr.host=solr6
-Dsolr.port=8983
-Dshare.port=8080
-Xms1500m
-Xmx1500m
volumes:
- /datos/alf_data:/usr/local/tomcat/alf_data
transform-router:
mem_limit: 512m
image: quay.io/alfresco/alfresco-transform-router:1.3.0-RC1
environment:
ACTIVEMQ_URL: "nio://activemq:61616"
CORE_AIO_URL: "http://transform-core-aio:8090"
FILE_STORE_URL: "http://shared-file-store:8099/alfresco/api/-default-/private/sfs/versions/1/file"
ports:
- 8095:8095
links:
- activemq
transform-core-aio:
image: alfresco/alfresco-transform-core-aio:2.2.2
mem_limit: 1536m
environment:
JAVA_OPTS: " -Xms256m -Xmx1536m"
ports:
- 8090:8090
links:
- activemq
share:
image: alfresco/alfresco-share:6.2.2-RC2
mem_limit: 1g
environment:
REPO_HOST: "alfresco"
REPO_PORT: "8080"
JAVA_OPTS: " -Xms500m -Xmx500m -Dalfresco.host=localhost -Dalfresco.port=8080 -Dalfresco.context=alfresco -Dalfresco.protocol=http "
solr6:
image: alfresco/alfresco-search-services:1.4.2
mem_limit: 2g
environment:
#Solr needs to know how to register itself with Alfresco
- SOLR_ALFRESCO_HOST=alfresco
- SOLR_ALFRESCO_PORT=8080
#Alfresco needs to know how to call solr
- SOLR_SOLR_HOST=solr6
- SOLR_SOLR_PORT=8983
#Create the default alfresco and archive cores
- SOLR_CREATE_ALFRESCO_DEFAULTS=alfresco,archive
#HTTP by default
- ALFRESCO_SECURE_COMMS=none
- "SOLR_JAVA_MEM=-Xms2g -Xmx2g"
ports:
- 8083:8983 #Browser port
volumes:
- /datos/solr_data:/opt/alfresco-search-services/data
activemq:
image: alfresco/alfresco-activemq:5.15.8
mem_limit: 1g
ports:
- 8161:8161 # Web Console
- 5672:5672 # AMQP
- 61616:61616 # OpenWire
- 61613:61613 # STOMP
digital-workspace:
image: quay.io/alfresco/alfresco-digital-workspace:1.5.0
mem_limit: 128m
environment:
BASE_PATH: ./
proxy:
image: alfresco/alfresco-acs-nginx:3.0.1
mem_limit: 128m
depends_on:
- alfresco
- digital-workspace
ports:
- 8080:8080
links:
- digital-workspace
- alfresco
- share
sync-service:
image: quay.io/alfresco/service-sync:3.3.2-Oracle
build:
context: ./sync-service
mem_limit: 1g
environment:
JAVA_OPTS: " -Dsql.db.driver=oracle.jdbc.OracleDriver -Dsql.db.url=jdbc
racle:thin:@<db_server>:<db_port>:<db_instance> -Dsql.db.username=<db_user> -Dsql.db.password=<passw> -Dmessaging.broker.host=activemq -Drepo.hostname=alfresco -Drepo.port=8080 -Ddw.server.applicationConnectors[0].type=http -Xms1000m -Xmx1000m "
ports:
- 9090:9090
And these related Dockerfiles:
- Dockerfile for the "alfresco" service:
FROM alfresco/alfresco-content-repository:6.2.2-RC1
COPY ./ojdbc8.jar /usr/local/tomcat/lib
- Dockerfile for the "sync-service" service:
FROM quay.io/alfresco/service-sync:3.3.2
USER root
COPY ./ojdbc8.jar /opt/alfresco-sync-service/connectors
RUN chmod -R 777 /opt/alfresco-sync-service/*
RUN chgrp -R Alfresco /opt/alfresco-sync-service
RUN chown -R dsync:Alfresco /opt/alfresco-sync-service
USER dsync
Do you see anything wrongor improvable?
BTW, Is there a new, official docker-compose for version 3 (this ones uses version 2, quite old)?
09-11-2020 04:00 AM
Version 2 is the latest version ,https://github.com/Alfresco/acs-deployment/tree/master/docker-compose
09-14-2020 07:21 AM
What about the /opt/alfresco-search-services/contentstore? Shouldn't it be also mapped to an external volume?
Regards
09-14-2020 10:16 PM
You can map index data directory ,contentstore directory,solrhome directory out based on your requirements
- your data pah :/opt/alfresco-search-services/data
- your contentstore pah :/opt/alfresco-search-services/contentsotre - your solr home path:/opt/alfresco-search-services/solrhome
