A guide on Installing and configuring non-docker 201901GA (or any 6.x) ?
wclemo
I am looking for help on installing and configuring the ver 6.x ACS community edition manually. I don't want to use docker. I want to install manually via the distribution zip. All my installations attempts for various v6x versions have been unsuccessful, usually with Alfresco failing to start up successfully. I noticed that there are several setup guides on the net for previous versions but one can hardly get version 6 ones (I wonder how the uptake of ver 6 is !!). The only manual install guide I found is the script https://community.alfresco.com/community/ecm/blog/2019/02/05/a-script-to-install-alfresco-community-...  but somehow it didn't work for me. I also followed the official Alfresco guide but despite several days attempts I didn't succeed.
I must mention that java, tomcat and various apps that Alfresco uses are not my sphere. Just out of curiosity I tried the docker install and it worked "out of the box", but as I mentioned I dont want to do docker. For those who have managed to do a successful manual install, would you care to kindly share your step by step notes ?
Thanks in advance
Clemo
Also this guide can help you, it's still valid for Alfresco 6:
http://beecon.buzz/2017/assets/files/EF09/EF09-Installing-Alfresco-components-1-by-1.pdf
Hyland Developer Evangelist
12 REPLIES 12
Can you please document the installation procedure as i am facing problem in installation I had tried multiple time but it is not working i am using Ubuntu 18.04 LTS.
Thanks and Regards
Akash
paula21
Hi, how are you? Dear cpn the script link on github, i can't get it to work. Maybe it is for my linux is debian 10.4 ?. I pay you to help me do a zero installation with version 6.2, from now thank you very much and I hope you can help me or at least pass me the script that you edited and with which the installation worked for you. Thank you in advance for the prompt response. Atte: paula
Get done at first time.
Thank you.
