org.activiti.engine.ActivitiException: unknown variable type
kartikla
HI All
I am trying to create a simple workflow using JPA. I have one service task which persists the data into a custom table using JPA and returns a JPA entity. Then i have a User Task where i want to display an attribute from the returned JPA entity. Now whether i blank user task or a user task with the entity attirbute, i get the error below when i click on the user task from the activit-explorer. I can see the correct data in ACT_RU_VARIABLE table as well and the type_ column indicates jpa-entity . What am i missing here ? How can i fix this prioblem…Please Advice…
Caused by: org.apache.ibatis.exceptions.PersistenceException:
### Error querying database.  Cause: org.activiti.engine.ActivitiException: unknown variable type name jpa-entity
### The error may exist in org/activiti/db/mapping/entity/VariableInstance.xml
### The error may involve org.activiti.engine.impl.persistence.entity.VariableInstanceEntity.selectVariablesByExecutionId-Inline
### SQL: select * from ACT_RU_VARIABLE    where EXECUTION_ID_ = ?     and TASK_ID_ is null
### Cause: org.activiti.engine.ActivitiException: unknown variable type name jpa-entity
        at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:104)
        at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:95)
        at org.activiti.engine.impl.db.DbSqlSession.selectListWithRawParameter(DbSqlSession.java:302)
        at org.activiti.engine.impl.db.DbSqlSession.selectList(DbSqlSession.java:293)
        at org.activiti.engine.impl.db.DbSqlSession.selectList(DbSqlSession.java:288)
        at org.activiti.engine.impl.db.DbSqlSession.selectList(DbSqlSession.java:269)
        at org.activiti.engine.impl.persistence.entity.VariableInstanceEntityManager.findVariableInstancesByExecutionId(VariableInstanceEntityManager.java:34)
        at org.activiti.engine.impl.persistence.entity.ExecutionEntity.loadVariableInstances(ExecutionEntity.java:995)
        at org.activiti.engine.impl.persistence.entity.VariableScopeImpl.ensureVariableInstancesInitialized(VariableScopeImpl.java:59)
        at org.activiti.engine.impl.persistence.entity.VariableScopeImpl.getVariableNamesLocal(VariableScopeImpl.java:163)
        at org.activiti.engine.impl.persistence.entity.VariableScopeImpl.deleteVariablesInstanceForLeavingScope(VariableScopeImpl.java:207)
        at org.activiti.engine.impl.persistence.entity.ExecutionEntity.destroy(ExecutionEntity.java:327)
        at org.activiti.engine.impl.pvm.runtime.AtomicOperationProcessEnd.eventNotificationsCompleted(AtomicOperationProcessEnd.java:61)
        at org.activiti.engine.impl.pvm.runtime.AbstractEventAtomicOperation.execute(AbstractEventAtomicOperation.java:56)
        at org.activiti.engine.impl.interceptor.CommandContext.performOperation(CommandContext.java:86)
        at org.activiti.engine.impl.persistence.entity.ExecutionEntity.performOperationSync(ExecutionEntity.java:530)
        at org.activiti.engine.impl.persistence.entity.ExecutionEntity.performOperation(ExecutionEntity.java:525)
        at org.activiti.engine.impl.pvm.runtime.AbstractEventAtomicOperation.execute(AbstractEventAtomicOperation.java:49)
        at org.activiti.engine.impl.pvm.runtime.AtomicOperationActivityEnd.eventNotificationsCompleted(AtomicOperationActivityEnd.java:54)
        at org.activiti.engine.impl.persistence.entity.ExecutionEntity.end(ExecutionEntity.java:338)
        at org.activiti.engine.impl.bpmn.behavior.NoneEndEventActivityBehavior.execute(NoneEndEventActivityBehavior.java:24)
        at org.activiti.engine.impl.pvm.runtime.AtomicOperationActivityExecute.execute(AtomicOperationActivityExecute.java:44)
        at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerStart.eventNotificationsCompleted(AtomicOperationTransitionNotifyListenerStart.java:52)
        at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionCreateScope.execute(AtomicOperationTransitionCreateScope.java:49)
Caused by: org.activiti.engine.ActivitiException: unknown variable type name jpa-entity
        at org.activiti.engine.impl.db.IbatisVariableTypeHandler.getResult(IbatisVariableTypeHandler.java:40)
        at org.activiti.engine.impl.db.IbatisVariableTypeHandler.getResult(IbatisVariableTypeHandler.java:32)
        at org.apache.ibatis.executor.resultset.FastResultSetHandler.getPropertyMappingValue(FastResultSetHandler.java:314)
        at org.apache.ibatis.executor.resultset.FastResultSetHandler.applyPropertyMappings(FastResultSetHandler.java:295)
        at org.apache.ibatis.executor.resultset.FastResultSetHandler.getRowValue(FastResultSetHandler.java:264)
        at org.apache.ibatis.executor.resultset.FastResultSetHandler.handleRowValues(FastResultSetHandler.java:214)
        at org.apache.ibatis.executor.resultset.FastResultSetHandler.handleResultSet(FastResultSetHandler.java:186)
        at org.apache.ibatis.executor.resultset.FastResultSetHandler.handleResultSets(FastResultSetHandler.java:152)
        at org.apache.ibatis.executor.statement.PreparedStatementHandler.query(PreparedStatementHandler.java:57)
        at org.apache.ibatis.executor.statement.RoutingStatementHandler.query(RoutingStatementHandler.java:70)
        at org.apache.ibatis.executor.SimpleExecutor.doQuery(SimpleExecutor.java:57)
        at org.apache.ibatis.executor.BaseExecutor.queryFromDatabase(BaseExecutor.java:267)
        at org.apache.ibatis.executor.BaseExecutor.query(BaseExecutor.java:141)
        at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:105)
        at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:81)
        at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:101)
        … 119 more
Kartik
frederikherema1
How does your process-engine configuration look? The jpa-variable is only added if the right properties are set (see user guide for JPA-config)…
