04-04-2011 06:19 AM
<serviceTask id="mailtask1" name="Mail" activiti:type="mail">
<extensionElements>
<activiti:field name="to" expression="${invites[loopCounter]}"></activiti:field>
<activiti:field name="from" expression="xxxxxxxxxxxxxxx"></activiti:field>
<activiti:field name="subject" expression="XXXXXXXXXXXXXXXX"></activiti:field>
<activiti:field name="html">
<activiti:expression><![CDATA[
XXXXXXX
!]]></activiti:expression>
</activiti:field>
</extensionElements>
<multiInstanceLoopCharacteristics isSequential="false">
<loopCardinality>5</loopCardinality>
</multiInstanceLoopCharacteristics>
</serviceTask>
04-04-2011 07:21 AM
PS : It is also very annoying that the Eclipse Designer removes the "multiInstanceLoopCharacteristics" node when we update the process diagram visually. This, however, seems normal.
04-04-2011 10:33 AM
04-04-2011 10:51 AM
04-04-2011 11:16 AM
04-05-2011 04:06 AM
04-05-2011 08:44 AM
<process id="testProcess" name="Processus de test">
<serviceTask id="servicetask1" name="Service Task" activiti:class="xxxxxxxx.EchoTask">
</serviceTask>
<sequenceFlow id="flow2" name="" sourceRef="startevent1" targetRef="servicetask1"></sequenceFlow>
<sequenceFlow id="flow3" name="" sourceRef="servicetask1" targetRef="endevent1"></sequenceFlow>
</process>
- The "EchoTask" does nothing but write "Hello !" in the standard output (System.out.println).INFO: ProcessEngine default created
5 avr. 2011 12:42:03 org.activiti.engine.ProcessEngines initProcessEnginFromResource
INFO: initialised process engine default
5 avr. 2011 12:42:03 org.activiti.engine.impl.jobexecutor.JobAcquisitionThread run
INFO: JobAcquisitionThread starting to acquire jobs
5 avr. 2011 12:42:03 org.activiti.engine.impl.bpmn.deployer.BpmnDeployer deploy
INFO: Processing resource TestProcess.bpmn20.xml
5 avr. 2011 12:42:03 org.activiti.engine.impl.bpmn.parser.BpmnParse parseDefinitionsAttributes
INFO: XMLSchema currently not supported as typeLanguage
INFO: XPath currently not supported as expressionLanguage
Hello !
04-06-2011 04:39 AM
04-06-2011 05:31 AM
04-06-2011 07:32 AM
