how to define a AVM target in deployment engine?
yahoon
I am testing 3.2's deployment function .
I installed the standalone deployment engine on my target server.
first I tested the File System target to deploy the files into a dir of this server.
      Modified the sample default-target.xml, define the destination dir , then started the engine.
deployment process is OK.
then I wanted to test the AVM target to deploy the files into the alfresco repo.
there is not any sample config file ,such as default-target.xml above.
How can I define it?
how to configure it in the WCM project settings.
5 REPLIES 5
mrogers
There's already a target provided which is called "avm" which is provided by the out of the box install.   This will deploy to an AVM repository in a similar way to the old ASR (although it is implemented completly differently).
The avm target can't be instaled in the standalone deployment engine since it needs running repo for authentication and the avm service.
mrogers
http://wiki.alfresco.com/wiki/AVM_Deployment_Target
To configure the WCM side of things in the project definition wizard.
The target name is "avm" and the "port number" is probably 50500.
That and the "hostname" should be all you need to specify.
yahoon
I created a web project named as test.
how can I deploy a WCM into this project ?
mrogers
You can't deploy into a web project.   You deploy from a web project to your web runtime.
samuel_penn
If you deploy into a target Alfresco server which already has a WCM project of the same name, the project will be deployed into that.
Sam.
