Advanced search SLOW!
lmoulin
I have a large number of documents in the Alfresco repository (~100 000 documents).
The advanced search takes lots of time to return the results (~more than 60 seconds)
I use only the custom criteria to perform the advanced search.
I don’t use the google like search and the full text search.
I have set the following value in web-client-config.xml:
<search-max-results>100</search-max-results>
Have you got a hack to increase the performances of the advanced search?
Thanks a lot.
Luc
15 REPLIES 15
lmoulin
Theoretically,
The query '+@\{my.new.model\}erd_commercialisateur:"GAZ ELECTRICITE DE GRENOBLE" AND (( TYPE:"{my.new.model}custom_root_type" OR TYPE:"{http://www.alfresco.org/model/content/1.0}folder" )) ' returns 100 000 documents.
But, when I execute a query which returns only 10 documents, it is very faster (~10 seconds).
Why this big variation?
Thanks a lot
Luc
lmoulin
My database has the following properties:
CREATE DATABASE "ERD1.0"
  WITH OWNER = erd
       ENCODING = 'LATIN1'
       TABLESPACE = pg_default;
andy
Hi
As Derek says, Postgress was not supported or tested on V1.4 community. Issues with its use - mainly performance have been fixed in the enterprise code. You can get these fixes by paying for support or you will have to wait until the fixes are in a later community release.
None of the other issues have anything to do with your performance problem.
Regards
Andy
lmoulin
I have installed my application on Oracle and the advanced search runs well.
Thanks a lot.
lmoulin
Has this PostGre bug been fixed in the latest version?
Thanks a lot,
Luc
kevinr
I believe this was an Enterprise fix and made it into 2.0E and 1.4.2E (i think) the fix should be in HEAD now so will be in the 2.1 Community release.
Kevin
