Problem with pdfjs-dist on build
ilseva
when we try to build (npm run-script build:dist -- --source-map=true) a project created with adf-cli-acs-template, the build fails with this message
ERROR in scripts.9d7058f51ab079a5b4f2.js from Terser
Unexpected token: punc (.) [node_modules/pdfjs-dist/build/pdf.js:2205,0][scripts.9d7058f51ab079a5b4f2.js:2205,45]
node version: 12.18.2
npm version: 6.14.13.
Any idea?
Sevastian
ilseva
We resolved using version specified in ADF application generator version 4.4.0.
 "pdfjs-dist": "2.5.207",
We started development using 4.3.0.
ilseva
EddieMay
World-Class Innovator
Hi @ilseva
Great news that you resolved your problem and thanks for updating us on how you did it - really useful to other members facing the same problem.
Thanks again,
Digital Community Manager, Alfresco Software.
