07-30-2019 07:54 PM
Hello! I am newbie to Activiti and I have 2 question that need someone can help me to understand:
How cache works in Activiti? Can we filter the cache? If yes, can you suggest me some ways to do?
As far as I know, there is a cache module in Camunda that helps filter activiti, is there any module in Activiti works like that?
I am also want to deeper dive in Activiti. Can you suggest for me some learning resource?
Thank you very much!
07-31-2019 07:03 AM
Here are some details on activiti cache:
https://docs.alfresco.com/process-services1.7/topics/process_definition_cache.html
Tweaking the cache (may be helpful in your case): http://www.jorambarrez.be/blog/2012/12/20/tweaking-process-definition-cache/
Getting started with activiti:
https://www.activiti.org/userguide/
If you are interested in APS, then follow "Getting started with alfresco process services": https://docs.alfresco.com/process-services1.7/topics/getting-started.html
07-31-2019 07:03 AM
