02-06-2020 10:29 PM
Hello everyone,
I have created custom surf page in Alfresco share and want it to open via custom header field added next to Admin Tools in share header bar. I am following this blog
I am able to access new surf page via its link but not able to add custom header field. I am using SDK 4 and path for the share-header.lib.js file is /sdk4-share/src/main/resources/alfresco/web-extension/site-webscripts/org/alfresco/share/imports/share-header.lib.js.
Is this the correct way to override share-header.lib.js via SDK? How can I achieve this?
Dhurmil
02-07-2020 05:28 AM
Please refer this document: https://docs.alfresco.com/6.2/concepts/dev-extensions-share-surf-extension-modules.html
Extending share header: https://docs.alfresco.com/6.2/concepts/dev-extensions-share-aikau-menus.html
02-07-2020 05:28 AM
02-11-2020 12:57 AM
02-11-2020 02:28 AM
Hi @dhrumilgosaliya,
Thanks for accepting the solution and for letting us know - helpful to other users having similar issues.
