04-28-2017 02:29 AM
When accessing the Alfresco icon the following page comes out (picture attached)
Jason
.png)
04-28-2017 04:21 AM
However you integrate the QNAP NAS system you have to make sure that it is completely transparent to Alfresco, e.g. that username / password are already handled as part of the filesystem mount. I honestly have never seen a prompt from a NAS storage pass through all the Alfresco layers to be presented to the end user, and since I have no way of reproducing such a scenario I cannot give you any more detailed insight.
You should probably not "install" Alfresco on the NAS system itself and only use it for the content store (configured in alfresco-global.properties via dir.contentstore property - or indirectly via dir.root property).
04-28-2017 04:28 AM
Hi Axel,
Many thanks for your reply.
Will try to follow your advice, and if I have more will try to solve this problem.
Thanks again
Jason
