Bootstrapping ModuleComponents with versions does not work
kartech11
Hi Alfresco Experts,
Please can you tell me why bootstrapping is not working as expected? I am putting my share and platform jar under .
/opt/alfresco/app/alfresco/modules/share/ and /opt/alfresco/app/alfresco/modules/platform
Currently, I see that the first JAR (5.1 version) that I added got picked up by alfresco. I then added but the next versioned JAR (5.2) but that did not get picked up by alfresco. The logs do say that the jar version has been upgraded.  But I don't see the changes getting applied by alfresco.
1. I have tried both the ImporterModuleComponents with the same moduleId but different versions ((higher version to the previous) - This does not work
2. I have also tried have different names and different version (higher version to the previous) - This also does not work
3. I also added a depends On with the higher version dependent on the lower version. This also does not work
<bean id="com.test.alfresco.bootstrap.site.sg"
      class="org.alfresco.repo.module.ImporterModuleComponent"
      parent="module.baseComponent">
    <!-- Module Details -->
    <property name="moduleId" value="alfresco-bootstrap-platform-jar" />
    <property name="name" value="test-sg" />
    <property name="description" value="Bootstrap test SG site" />
    <property name="sinceVersion" value="5.1" />
    <property name="appliesFromVersion" value="5.1" />
    <!-- Data properties -->
    <property name="importer" ref="spacesBootstrap"/>
    <property name="bootstrapViews">
        <list>
            <props>
                <prop key="path">/${alfresco_user_store.system_container.childname}</prop>
                <prop key="location">alfresco/module/${project.artifactId}/bootstrap/sites/test-sg/groups.xml</prop>
            </props>
            <props>
                <prop key="path">/${spaces.company_home.childname}/${spaces.sites.childname}</prop>
                <prop key="location">alfresco/module/${project.artifactId}/bootstrap/sites/test-sg/Contents.acp</prop>
            </props>
        </list>
    </property>
</bean>
<bean id="com.test.alfresco.bootstrap.test.sg.folders"
    <property name="name" value="test-sg-folders" />
    <property name="description" value="test SG folders" />
    <property name="sinceVersion" value="5.2" />
    <property name="appliesFromVersion" value="5.2" />
        <list>
            <props>
                <prop key="path">/${spaces.company_home.childname}/${spaces.sites.childname}/cm:test-sg/cm:documentLibrary</prop>
                <prop key="location">alfresco/module/alfresco-bootstrap-platform-jar/bootstrap/bootstrap-folders.xml</prop>
            </props>
        </list>
    </property>
</bean>
5 REPLIES 5
angelborroy
Community Manager
Once a patch has been applied to an Alfresco installation, it's not applied anymore.
You should change "moduleId" value in order to be loaded.
Hyland Developer Evangelist
I changed the moduleId to a different name and also increased the version., but that did not import the new module with the higher version. Not sure what I am missing here.
Have you tried with...
 <property name="executeOnceOnly" value="false" />
But won't that try executing the module every time alfresco starts up? That will cause issues if my importer is bootstrapping content model or sites for example, isn't it?
Yes.
You can also change your strategy and use "org.alfresco.repo.admin.patch.impl.GenericBootstrapPatch" instead.
