05-31-2022 09:12 AM
I'm using (from almost 2 years) Alfresco Enterprise 5.2.4 and libreoffice as a jodconverter.
Last end of years, I began to have trouble with jodvonverter but a simple soffice service restart was working.
This is not the case anymore. I even restarted the server but impossible to have any transformation
I can't figure out was it this "code = 81" and I can't find how to change the command (after searching it look like --headless option is not that good and should not be use to run process in background)
Could someone help me ?
Thanks !
mai 11, 2022 8:11:26 AM org.artofsolving.jodconverter.office.ProcessPoolOfficeManager <init> INFOS: ProcessManager implementation is LinuxProcessManager mai 11, 2022 8:11:26 AM org.artofsolving.jodconverter.office.OfficeProcess start INFOS: Using original OpenOffice command: [/opt/alfresco-content-services/libreoffice/program/soffice.bin, -accept=socket,host=127.0.0.1,port=8100;urp;, -env:UserInstallation=file:///opt/alfresco-content-services/tomcat/temp/.jodconverter_socket_host-127.0.0.1_port-8100, -headless, -nocrashreport, -nodefault, -nofirststartwizard, -nolockcheck, -nologo, -norestore] mai 11, 2022 8:11:26 AM org.artofsolving.jodconverter.office.OfficeProcess start INFOS: starting process with acceptString 'socket,host=127.0.0.1,port=8100,tcpNoDelay=1' and profileDir '/opt/alfresco-content-services/tomcat/temp/.jodconverter_socket_host-127.0.0.1_port-8100' mai 11, 2022 8:11:26 AM org.artofsolving.jodconverter.office.OfficeProcess start INFOS: started process; pid = 5553 mai 11, 2022 8:11:27 AM org.artofsolving.jodconverter.office.ManagedOfficeProcess$6 attempt AVERTISSEMENT: office process died with exit code 81; restarting it
05-31-2022 11:13 AM
This seems like some known issues based on what i found, you can check here:
https://github.com/sbraconnier/jodconverter/issues/48
https://github.com/unoconv/unoconv/issues/192
However, Can you share your jodconvertor configs from alfresco-global.properties ? so we can take a look.
Within Alfresco, you can transform a document from one format to another. This feature requires you to install LibreOffice or OpenOffice.org.
OOoJODconverter
The JODConverter integration, which is a library that improves the stability and performance of OpenOffice.org or LibreOffice within Alfresco. The OOoJODConverter runs on the same machine as the Alfresco server and it supports:
- a pool of separate OpenOffice processes
- automatic restart of crashed OpenOffice processes
- automatic termination of slow OpenOffice operations
- automatic restart of any OpenOffice process after a number of operations (this is a workaround for OpenOffice memory leaks)
OOoDirect
The subsystem for direct OpenOffice integration, in which the Alfresco server manages OpenOffice directly. To enable or disable this subsystem, use the following property:
ooo.enabled=false/true
By default, the OOoDirect subsystem is enabled, and the OOoJodconverter subsystem is disabled. Although it is possible to run both subsystems, Alfresco recommends that you enable only one at a time. To take advantage of the stability and performance benefits of the OOoJodconverter subsystem, ensure that you disable OOoDirect and enable OOoJodConverter using the following properties in the alfresco-global.properties file:
ooo.enabled=false
jodconverter.enabled=true
alfresco-pdf-renderer.root=C:/alfresco-community62ga/alfresco-pdf-renderer
alfresco-pdf-renderer.exe=${alfresco-pdf-renderer.root}/alfresco-pdf-renderer.exe img.root=C:/alfresco-community62ga/imagemagick img.dyn=${img.root}/lib img.exe=${img.root}/convert.exe img.coders=${img.root}/modules/coders img.config=${img.root} img.gslib=${img.root}/lib ooo.exe=C:/alfresco-community62ga/libreoffice/program/soffice.exe ooo.enabled=false ooo.port=8100 jodconverter.enabled=true jodconverter.officeHome=C:/alfresco-community62ga/libreoffice jodconverter.portNumbers=8100
06-01-2022 02:51 AM
Many thanks for the answers
I'm using libreoffice with this configuration :
### External executable locations ###
ooo.exe=/opt/alfresco-content-services/libreoffice/program/soffice.bin
ooo.enabled=false
ooo.port=8100
img.root=/opt/alfresco-content-services/common
img.exe=${img.root}/bin/convert
alfresco-pdf-renderer.root=/opt/alfresco-content-services/common/alfresco-pdf-renderer
jodconverter.officeHome=/opt/alfresco-content-services/libreoffice
jodconverter.portNumbers=8100I already saw the two links, thank you again, but it suggest to update some Java code .. I guess it's alfresco code and I don't know how to do this ..
I also found some detailed thread indicating that the issue is with the "headless" option .. but I did not found how to modify the way Alfresco start jodconverter .. have you any idea ?
06-08-2022 09:51 AM
ooo.enabled=false
Having above properties set, alfresco is able to manage the startup and shutdown of the services itself. I did not get into much details on those links.
It is almost not practical to change a code as it is still not sure whether it is code issue or environment issue. Can you also check the libreoffice version you are running with ACS5.2: https://docs.alfresco.com/content-services/5.2/support/
Make sure it is matching.
Here is repo in case you want to refer, a lot has been changed since 5.2, all transformation related items are also moved to a different service:
https://github.com/Alfresco/alfresco-community-repo
https://github.com/Alfresco/alfresco-transform-core
06-09-2022 02:35 AM
Thanks for the answer
versions are matching, I'm using LibreOffice 5.2.
I'm about to update Alfresco from 5 to 7 but it will take time ..
Waiting for the new version, is there a way I can't add another service to transfort doc* to pdf ?
