Tomcat doesn't start intermittently when using postgresql
hari
Hi All,
I come across this issue very often. The only thing I have done up till now to get rid of this was to delete activiti-explorer folder from tomcat webapps and then start again. But I really need to understand whats going wrong.
It always gets struck at this message on screen
11:21:28,309 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/simple-approval.bpmn20.xml
There is nothing written in tomcat logs to see what went wrong.
Need your help to resolve this. Thanks.
Below is what I see on screen when I start tomcat.  As you can see, it gets struck at "Processing resource org/activiti/explorer/demo/
process/simple-approval.bpmn20.xml"
27-Apr-2015 11:21:00.753 INFO [main] org.apache.catalina.core.AprLifecycleListener.init The APR based Apache Tomcat Native library which al
lows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jdk1.7.0_76\bin;C:\Window
s\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell
\v1.0\;C:\Program Files\TortoiseSVN\bin;C:\Program Files (x86)\Apache Software Foundation\apache-maven-3.2.5\bin;C:\Program Files (x86)\Sky
pe\Phone\;.
27-Apr-2015 11:21:01.462 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
27-Apr-2015 11:21:01.533 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write
/read
27-Apr-2015 11:21:01.541 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
27-Apr-2015 11:21:01.555 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write
/read
27-Apr-2015 11:21:01.557 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1840 ms
27-Apr-2015 11:21:01.659 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
27-Apr-2015 11:21:01.660 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.9
27-Apr-2015 11:21:01.791 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive 😧
\Tomcat\apache-tomcat-8.0.9\webapps\activiti-explorer.war
27-Apr-2015 11:21:01.857 WARNING [localhost-startStop-1] org.apache.catalina.startup.SetContextPropertiesRule.begin [SetContextPropertiesRu
le]{Context} Setting property 'antiJARLocking' to 'true' did not find a matching property.
11:21:20,176 [localhost-startStop-1] INFO  org.springframework.web.context.support.AnnotationConfigWebApplicationContext  - Refreshing Root
WebApplicationContext: startup date [Mon Apr 27 11:21:20 IST 2015]; root of context hierarchy
11:21:20,525 [localhost-startStop-1] INFO  org.springframework.web.context.support.AnnotationConfigWebApplicationContext  - Registering ann
otated classes: [class org.activiti.explorer.conf.ApplicationConfiguration]
11:21:20,938 [localhost-startStop-1] INFO  org.springframework.beans.factory.xml.XmlBeanDefinitionReader  - Loading XML bean definitions fr
om class path resource [activiti-ui-context.xml]
11:21:21,357 [localhost-startStop-1] INFO  org.springframework.beans.factory.xml.XmlBeanDefinitionReader  - Loading XML bean definitions fr
om class path resource [activiti-login-context.xml]
11:21:21,386 [localhost-startStop-1] INFO  org.springframework.beans.factory.xml.XmlBeanDefinitionReader  - Loading XML bean definitions fr
om class path resource [activiti-custom-context.xml]
11:21:21,430 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'dataSource': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyCheck=0; au
towireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=dataSource; initMethodName=null; destro
yMethodName=(inferred); defined in class path resource [org/activiti/explorer/conf/ActivitiEngineConfiguration.class]] with [Generic bean:
class [org.apache.commons.dbcp.BasicDataSource]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandida
te=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in class path re
source [activiti-custom-context.xml]]
11:21:21,434 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'transactionManager': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyChe
ck=0; autowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=annotationDrivenTransactionMana
ger; initMethodName=null; destroyMethodName=(inferred); defined in class path resource [org/activiti/explorer/conf/ActivitiEngineConfigurat
ion.class]] with [Generic bean: class [org.springframework.jdbc.datasource.DataSourceTransactionManager]; scope=; abstract=false; lazyInit=
false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodNa
me=null; destroyMethodName=null; defined in class path resource [activiti-custom-context.xml]]
11:21:21,440 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'processEngineConfiguration': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; depen
dencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=processEngineConfigurat
ion; initMethodName=null; destroyMethodName=(inferred); defined in class path resource [org/activiti/explorer/conf/ActivitiEngineConfigurat
ion.class]] with [Generic bean: class [org.activiti.spring.SpringProcessEngineConfiguration]; scope=; abstract=false; lazyInit=false; autow
ireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; des
11:21:21,443 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'processEngine': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyCheck=0;
autowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=processEngine; initMethodName=null;
destroyMethodName=(inferred); defined in class path resource [org/activiti/explorer/conf/ActivitiEngineConfiguration.class]] with [Generic
bean: class [org.activiti.spring.ProcessEngineFactoryBean]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; auto
wireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=destroy; defined in
11:21:21,445 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'repositoryService': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyChec
k=0; autowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=repositoryService; initMethodNam
e=null; destroyMethodName=(inferred); defined in class path resource [org/activiti/explorer/conf/ActivitiEngineConfiguration.class]] with [
Generic bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=fals
e; factoryBeanName=processEngine; factoryMethodName=getRepositoryService; initMethodName=null; destroyMethodName=null; defined in class pat
11:21:21,446 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'runtimeService': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyCheck=0
; autowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=runtimeService; initMethodName=null
; destroyMethodName=(inferred); defined in class path resource [org/activiti/explorer/conf/ActivitiEngineConfiguration.class]] with [Generi
c bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; fac
toryBeanName=processEngine; factoryMethodName=getRuntimeService; initMethodName=null; destroyMethodName=null; defined in class path resourc
11:21:21,448 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'taskService': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyCheck=0; a
utowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=taskService; initMethodName=null; dest
royMethodName=(inferred); defined in class path resource [org/activiti/explorer/conf/ActivitiEngineConfiguration.class]] with [Generic bean
: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBe
anName=processEngine; factoryMethodName=getTaskService; initMethodName=null; destroyMethodName=null; defined in class path resource [activi
11:21:21,450 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'formService': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyCheck=0; a
utowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=formService; initMethodName=null; dest
anName=processEngine; factoryMethodName=getFormService; initMethodName=null; destroyMethodName=null; defined in class path resource [activi
11:21:21,452 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'historyService': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyCheck=0
; autowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=historyService; initMethodName=null
toryBeanName=processEngine; factoryMethodName=getHistoryService; initMethodName=null; destroyMethodName=null; defined in class path resourc
11:21:21,454 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'managementService': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyChec
k=0; autowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=managementService; initMethodNam
e; factoryBeanName=processEngine; factoryMethodName=getManagementService; initMethodName=null; destroyMethodName=null; defined in class pat
11:21:21,456 [localhost-startStop-1] INFO  org.springframework.beans.factory.support.DefaultListableBeanFactory  - Overriding bean definiti
on for bean 'identityService': replacing [Root bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=3; dependencyCheck=
0; autowireCandidate=true; primary=false; factoryBeanName=activitiEngineConfiguration; factoryMethodName=identityService; initMethodName=nu
ll; destroyMethodName=(inferred); defined in class path resource [org/activiti/explorer/conf/ActivitiEngineConfiguration.class]] with [Gene
ric bean: class [null]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; f
actoryBeanName=processEngine; factoryMethodName=getIdentityService; initMethodName=null; destroyMethodName=null; defined in class path reso
11:21:22,024 [localhost-startStop-1] INFO  org.springframework.beans.factory.config.PropertyPlaceholderConfigurer  - Loading properties fil
e from class path resource [ui.properties]
11:21:22,034 [localhost-startStop-1] INFO  org.springframework.beans.factory.config.PropertyPlaceholderConfigurer  - Loading properties fil
e from class path resource [db.properties]
11:21:27,118 [localhost-startStop-1] INFO  org.activiti.engine.impl.ProcessEngineImpl  - ProcessEngine default created
11:21:27,121 [localhost-startStop-1] INFO  org.activiti.engine.impl.jobexecutor.JobExecutor  - Starting up the JobExecutor[org.activiti.eng
ine.impl.jobexecutor.DefaultJobExecutor].
11:21:27,130 [Thread-5] INFO  org.activiti.engine.impl.jobexecutor.AcquireJobsRunnableImpl  - JobExecutor[org.activiti.engine.impl.jobexecu
tor.DefaultJobExecutor] starting to acquire jobs
11:21:27,255 [localhost-startStop-1] INFO  org.activiti.explorer.conf.DemoDataConfiguration  - Initializing demo groups
11:21:27,425 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/VacationRequest.png
11:21:27,436 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,439 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/FixSystemFailureProcess.bpmn20.xml
11:21:27,441 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,523 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,531 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,542 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,547 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,553 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,555 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,602 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,605 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,619 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,622 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,637 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,638 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,918 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/FixSystemFailureProcess.png
11:21:27,919 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,920 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/VacationRequest.bpmn20.xml
11:21:27,919 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,922 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,919 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,927 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,919 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,938 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,919 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,941 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,918 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,918 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,953 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,919 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:27,954 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,057 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/createTimersProcess.bpmn20.xml
11:21:28,057 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,057 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,057 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,065 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/reviewSalesLead.bpmn20.xml
11:21:28,072 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,057 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,057 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,057 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,057 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,086 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,082 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,070 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,125 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/reviewSalesLead.reviewSaledLead.png
11:21:28,138 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/Helpdesk.png
11:21:28,151 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
process/Helpdesk.bpmn20.xml
11:21:28,138 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,138 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,158 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,159 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,128 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,162 [pool-1-thread-6] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,125 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,166 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,169 [pool-1-thread-2] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,175 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,178 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,180 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,157 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,157 [pool-1-thread-1] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,148 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,190 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,146 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,143 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,229 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,243 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,254 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,196 [pool-1-thread-4] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,187 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,183 [pool-1-thread-7] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,260 [pool-1-thread-5] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,239 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,286 [pool-1-thread-8] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
11:21:28,295 [pool-1-thread-3] INFO  org.activiti.engine.impl.bpmn.deployer.BpmnDeployer  - Processing resource org/activiti/explorer/demo/
hari
All,
I had to use TextArea in my application and hence for that to work, I had to change the activiti-custom-context.xml and activiti-ui-context.xml files.
I am not really sure if the issue is there as tomcat starts for a few times and then it does not start.
Anyways, for your reference, I have attached them.
Hari.
jbarrez
Not sure what is going on here, can't see anything straight wrong. Did you validate it works without the custom changes? And then add in all the custom form property types one by one?
