12-19-2012 11:42 AM
12-20-2012 05:52 AM
Hi Water Man,
What version of IE are you runing?
Thanks.
12-31-2012 07:28 AM
IE 7.
12-31-2012 09:12 AM
Hi Water Man.
From what I can tell, you are using a custom file format for your Office 2007/2010 documents. Is this correct?
Thanks.
12-31-2012 09:28 AM
I found SCR: #141452 which documents the issue. At this time it has not been implemented in the software.
Take care.
