03-06-2018 05:46 AM
I have both Static and Dynamic Document Retention configured for a few Doc Types. I understand the need for a Purge processor to be run (manually or scheduled) to actually Delete / Purge the documents. However, I did expect that manual Delete and Re-index functions would NOT work from the regular document function options. What is not configured or running that needs to be?
What User permission needs to be turned on to see the Document Retention right-click menu that would allow for override of the Document Retention policies and allow for manual delete, re-index, hold and hold release? This menu does not appear to be working for the doc types I have Document Retention configured for.
THANKS!!!
03-06-2018 10:32 AM
Under Configuration Rights, the user must have the Process Configuration option selected to be able to access Document Retention from the Import menu.
The following privileges must be assigned to the user group via User Groups/Rights to enable selective retention functions in the Client module:
