do case insensitive search using nxql
ITShine_
i'm using Nxql to do search on my custom document types, but i've noticed that with this NXQL query :
<fixedPart>
                ecm:isCheckedInVersion = 0 AND
        				ecm:mixinType != 'HiddenInNavigation' AND
        				ecm:currentLifeCycleState != 'deleted' AND ecm:parentId = ? AND
        				ecm:primaryType = 'fiche_technique'
          </fixedPart>
the search is case sentitive, i mean "work" and "Work" are not the same with this query , can you tell what should i add in order to have a case insentitive search ?
Thierry_Martins
Star Collaborator
Star Collaborator
hello,
you need to use the ILIKE operator to do case insensitive search.
Regards
Thierry_Martins
Star Collaborator
Star Collaborator
hello,
Regards
