Fresh installation fails with "02110002 Required people system path not found: sys:system"
cajova_houba
we've encountered following error when installing fresh Alfresco (=Alfresco Content Services) on a clean server (empty contentstore folder and empty DB). The installation went fine, DB got initialized but then the Alfresco failed to start with mentioned error. Here's an exerpt from catalina.out:
2024-03-11 12:16:00,940  WARN  [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-1] Transformer "rfc822ToPdf" ignored as step transforms ("rfc822", "libreoffice") do not exist. Read from resource alfresco/transforms/0100-basePipelines.json
2024-03-11 12:16:00,940  WARN  [content.transform.LocalTransformServiceRegistry] [QuartzScheduler_Worker-1] Transformer "htmlToPdfViaTXT" ignored as step transforms ("string", "libreoffice") do not exist. Read from resource alfresco/transforms/0100-basePipelines.json
2024-03-11 12:16:16,324  INFO  [management.subsystems.ChildApplicationContextFactory] [main] Starting 'Search' subsystem, ID: [Search, managed, solr6]
2024-03-11 12:16:16,611  INFO  [management.subsystems.ChildApplicationContextFactory] [main] Startup of 'Search' subsystem, ID: [Search, managed, solr6] complete
2024-03-11 12:16:28,552  ERROR [web.context.ContextLoader] [main] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: 02110003 Workflow deployment failed
        at org.alfresco.repo.workflow.WorkflowDeployer.init(WorkflowDeployer.java:367)
        at org.alfresco.repo.workflow.WorkflowDeployer$1$1.doWork(WorkflowDeployer.java:590)
        at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:602)
        at org.alfresco.repo.workflow.WorkflowDeployer$1.execute(WorkflowDeployer.java:586)
        at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:452)
        at org.alfresco.repo.workflow.WorkflowDeployer.onBootstrap(WorkflowDeployer.java:581)
        at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEventInternal(SafeApplicationEventMulticaster.java:232)
        at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:197)
        at org.alfresco.repo.management.SafeApplicationEventMulticaster.multicastEvent(SafeApplicationEventMulticaster.java:217)
        at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:421)
        at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:378)
        at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:938)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:586)
        at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:401)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:292)
        at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
        at org.alfresco.web.app.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:70)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4769)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5231)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:726)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:698)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:696)
        at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:690)
        at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1889)
        at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
        at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
        at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
        at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123)
        at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:583)
        at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:473)
        at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1618)
        at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:319)
        at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
        at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
        at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
        at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:946)
        at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:835)
        at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1396)
        at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1386)
        at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145)
        at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:919)
        at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:265)
        at org.apache.catalina.core.StandardService.startInternal(StandardService.java:432)
        at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:930)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:772)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
        at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.base/java.lang.reflect.Method.invoke(Method.java:568)
        at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:476)
Caused by: org.alfresco.error.AlfrescoRuntimeException: 02110002 Required people system path not found: sys:system
        at org.alfresco.repo.security.person.PersonServiceImpl.getPeopleContainer(PersonServiceImpl.java:1178)
        at org.alfresco.repo.security.person.PersonServiceImpl.getPersonOrNullImpl(PersonServiceImpl.java:560)
        at org.alfresco.repo.security.person.PersonServiceImpl.getUserIdentifier(PersonServiceImpl.java:1936)
        at org.alfresco.repo.security.authority.AuthorityServiceImpl.isAdminAuthority(AuthorityServiceImpl.java:193)
        at org.alfresco.service.cmr.workflow.WorkflowPermissionInterceptor.invoke(WorkflowPermissionInterceptor.java:62)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
        at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:53)
        at org.alfresco.repo.audit.AuditMethodInterceptor.invoke(AuditMethodInterceptor.java:166)
        at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:123)
        at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:388)
        at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:119)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:215)
        at jdk.proxy3/jdk.proxy3.$Proxy79.isDefinitionDeployed(Unknown Source)
        at org.alfresco.repo.workflow.WorkflowDeployer.init(WorkflowDeployer.java:311)
        ... 58 more
 The main cause seems to be this:
The Alfresco in question is 7.3.0 Community edition. We've installed this one multiple times (even performed upgrade from 5.2 to 7.3) and haven't encountered such error yet. I have no idea what "sys:system" means. Can someone please clarify this error and maybe point where should I look for cause?
Thanks!
cajova_houba
I was able to finally find the cause of this problem. It's a filesystem issue. A filesystem permission issue to be precise. The content folder had following permissions and ownership:
drwxr-x---. 3 alfresco alfresco /var/opt/alfresco/content-services/content
The alfresco-content.service was run as user alfresco but apparently the tomcat was not able to read from the contentstore and thus was not able to resolve "sys:system" node.
Adding o=rx to contentstore permissions fixed the issue:
drwxr-xr-x. 3 alfresco alfresco /var/opt/alfresco/content-services/content
cajova_houba
