12-04-2019 05:46 AM
Good morning,
I'm using Alfresco Community Edition 5.2 and I need to access to Alfresco portal (http://localhost:8080/share/page) via the credentials put in on a previous own web page.
In summary, input the credentials in my web portal and pressing the link to my Alfresco repository, I log in directly to the documents repository without going through the Alfresco login.
I state that I am not using and I can't use external authentication systems like CAS, LDAP or similar.
Are there any API to do that?
Please let me know, if is possible.
Thanks in advance
Regards
Alex
12-04-2019 10:26 AM
Have you looked at this? https://docs.alfresco.com/community/references/dev-services-authentication.html
12-04-2019 10:48 AM
Thank you very much for your answer.
Yes, I've already looked it but there isn't a final step that can solve my trouble: pass the login information to Alfresco portal and open the document repository page directly. Or maybe I'm wrong? In this case, could you tell me exactly what I have to follow?
Thanks a lot again.
Regards
Alex
