APS Error connecting to Alfresco repository using Basic Authentication
mattinpute
Hi All,
I am running a docker compose using APS 2.4 and ACS 7.3, and have setup a connector to the Alfresco repository in APS using basic authentication.
However, when I go to configure an account using the admin credentials (or any other credentials) an error appears and on the backend the process container logs show:
com.fasterxml.jackson.core.JsonParseException: Unexpected character ('<' (code 60)): expected a valid value (JSON String, Number, Array, Object or token 'null', 'true' or 'false')
2023-11-02 12:41:34  at [Source: (org.apache.http.conn.EofSensorInputStream); line: 1, column: 2]
2023-11-02 12:41:34     at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:2418) ~[jackson-core-2.14.1.jar:2.14.1]
2023-11-02 12:41:34     at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:749) ~[jackson-core-2.14.1.jar:2.14.1]
2023-11-02 12:41:34     at com.fasterxml.jackson.core.base.ParserMinimalBase._reportUnexpectedChar(ParserMinimalBase.java:673) ~[jackson-core-2.14.1.jar:2.14.1]
2023-11-02 12:41:34     at com.fasterxml.jackson.core.json.UTF8StreamJsonParser._handleUnexpectedValue(UTF8StreamJsonParser.java:2784) ~[jackson-core-2.14.1.jar:2.14.1]
2023-11-02 12:41:34     at com.fasterxml.jackson.core.json.UTF8StreamJsonParser._nextTokenNotInObject(UTF8StreamJsonParser.java:907) ~[jackson-core-2.14.1.jar:2.14.1]
2023-11-02 12:41:34     at com.fasterxml.jackson.core.json.UTF8StreamJsonParser.nextToken(UTF8StreamJsonParser.java:793) ~[jackson-core-2.14.1.jar:2.14.1]
2023-11-02 12:41:34     at com.fasterxml.jackson.databind.ObjectMapper._initForReading(ObjectMapper.java:4761) ~[jackson-databind-2.13.4.2.jar:2.13.4.2]
2023-11-02 12:41:34     at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:4667) ~[jackson-databind-2.13.4.2.jar:2.13.4.2]
2023-11-02 12:41:34     at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3666) ~[jackson-databind-2.13.4.2.jar:2.13.4.2]
2023-11-02 12:41:34     at com.activiti.alfrescoconnector.service.AlfrescoServicesImpl.readReponse(AlfrescoServicesImpl.java:215) ~[activiti-app-alfresco-cloud-2.4.1.2.jar:2.4.1.2]
2023-11-02 12:41:34     at com.activiti.alfrescoconnector.service.AlfrescoContentService.getAllSites(AlfrescoContentService.java:93) ~[activiti-app-alfresco-cloud-2.4.1.2.jar:2.4.1.2]
2023-11-02 12:41:34     at com.activiti.service.runtime.integration.alfresco.AlfrescoOnPremService.getAllSites(AlfrescoOnPremService.java:269) ~[activiti-app-logic-2.4.1.2.jar:2.4.1.2]
2023-11-02 12:41:34     at com.activiti.rest.runtime.integration.AlfrescoOnPremResource.getAllSites(AlfrescoOnPremResource.java:82) ~[activiti-app-rest-2.4.1.2.jar:2.4.1.2]
2023-11-02 12:41:34     at com.activiti.rest.runtime.integration.AlfrescoOnPremResource$$FastClassBySpringCGLIB$$94b7eb10.invoke(<generated>) ~[activiti-app-rest-2.4.1.2.jar:2.4.1.2]
2023-11-02 12:41:34     at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218) ~[spring-core-5.3.29.jar:5.3.29]
2023-11-02 12:41:34     at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:793) ~[spring-aop-5.3.29.jar:5.3.29]
2023-11-02 12:41:34     at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163) ~[spring-aop-5.3.29.jar:5.3.29]
2023-11-02 12:41:34     at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.proceed(CglibAopProxy.java:763) ~[spring-aop-5.3.29.jar:5.3.29]
2023-11-02 12:41:34     at com.ryantenney.metrics.spring.TimedMethodInterceptor.invoke(TimedMethodInterceptor.java:48) ~[metrics-spring-3.1.3.jar:na]
2023-11-02 12:41:34     at com.ryantenney.metrics.spring.TimedMethodInterceptor.invoke(TimedMethodInterceptor.java:34) ~[metrics-spring-3.1.3.jar:na]
2023-11-02 12:41:34     at com.ryantenney.metrics.spring.AbstractMetricMethodInterceptor.invoke(AbstractMetricMethodInterceptor.java:59) ~[metrics-spring-3.1.3.jar:na]
2023-11-02 12:41:34     at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186) ~[spring-aop-5.3.29.jar:5.3.29]
2023-11-02 12:41:34     at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:708) ~[spring-aop-5.3.29.jar:5.3.29]
2023-11-02 12:41:34     at com.activiti.rest.runtime.integration.AlfrescoOnPremResource$$EnhancerBySpringCGLIB$$35efe50c.getAllSites(<generated>) ~[activiti-app-rest-2.4.1.2.jar:2.4.1.2]
2023-11-02 12:41:34     at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:na]
2023-11-02 12:41:34     at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[na:na]
2023-11-02 12:41:34     at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:na]
Any suggestions on what could be going wrong would be great. It seems that the response back is HTML instead of the expected JSON.
mattinpute
Turns out I was using the wrong URLs in the Alfresco respository configuration.
I forgot that when using docker containers you can't reach other containers using localhost, instead you need a fixed address like your local IP.
So I just changed the endpoint addresses in the configuration from localhost to my local IP and worked fine after that.
Stupid, but easy mistake to make Smiley Happy.
mattinpute
