Advanced Search on custom properties doesn't work
deny7
I'm running locally in Eclipse Alfresco AIO project. Share version is 5.2.f. Platform version is 5.2.g. SDK version 3.0.1.
I want to add custom advance search form which will search for my custom properties.
I did below steps but when I try to search for my custom property using my custom advanced search form it gives me ' 0 results ' every time.
I'm testing it like this:
1. I create random file in folder
2. then I change type of that file to 'ex:document', then I see my custom property field
3. I click on edit properties and I fill this field with some text.
4. Then I try to search for this property but it gives me 0 results.
I also checked solr.log, alfresco.log, share.log -- all without exception's.
Did I miss something? Is there any additional configuration needed? I'm assuming its problem with indexing in solr? Please can anybody help, I'm very new to Alfresco.
I did these steps:
I created my custom model exampleContentModel.xml file in location alfresco/module/model/:
<types>
              <!-- Custom types for advanced search forms -->
            <type name="ex:casesSearch">
                    <parent>ex:document</parent>
            </type>
<type name="ex:document">
            <parent>cm:content</parent>
            <properties>
                <property name="ex:clientName">
                    <type>d:text</type>
             </property>
</type>
</types>
Then I edited my share-config-custom.xml file where I added advanced search forms in location src/main/resources/META-INF/:
<config evaluator="node-type" condition="ex:document">
<forms>
<!-- Default form configuration for the cm:content type -->
<form>
<field-visibility>
<show id="cm:name" />
<show id="cm:title" force="true" />
<show id="cm:description" force="true" />
<show id="ex:clientName" force="true" />
</field-visibility>
<appearance>
<set id="docSet" appearance="bordered-panel"
label-id="form.set.label.document" />
<field id="ex:clientName" label-id="form.field.label.hypo.klantnaam" set="docSet" />
</appearance>
</form>
</config>
<!-- __________________________________ advance search form declaration _________________________________________________ -->
<config evaluator="model-type" condition="ex:casesSearch">
<forms>
<form id="search">
<field-visibility>
<show id="ex:clientName" />
</field-visibility>
</form>
</forms>
</config>
<!-- __________________________________ Advanced search form's configuration _________________________________________________ -->
<config evaluator="string-compare" condition="AdvancedSearch">
<advanced-search>
<!-- Forms for the advanced search type list -->
<forms>
<!-- The 'form' config element contains the name of the model type of
the form to display. The element supports the following optional attributes:
id = form id, the id of "search" will be assumed if not set label = label
text to display - defaults to model type if not set labelId = I18N message
id of label text to display description = description text to display descriptionId
= I18N message id of description text to display -->
<form labelId="Cases site"
descriptionId="search.form.desc.cm_folder">ex:casesSearch</form>
</forms>
</advanced-search>
</config>
sanjaybandhaniya
Elite Collaborator
Elite Collaborator
Please make property searchable.
Ex.
<property name="mcm:id">
      <type>d:text</type>
        <index enabled="true">
               <atomic>true</atomic>
                <stored>false</stored>
               <tokenised>false</tokenised>
          </index>
</property>
roberto_gamiz
You have defined a custom avanced form for type "ex:casesSearch" but  have created a content with the type "ex:document".
The "ex:casesSearch" avanced search form is going to filter for this type and metadata and never is going to find a content of type "ex:document".
Notice too,  that in the search result page you have to select if the search is done for all ther repository or only in the sites.
