Hi there,
First of all, I know that Activiti 5.13 run with Spring 3.1.2. I'm developer of the Grails Activiti Plugin, the plugin is cease to execute in latest version of Grails 2.3.0 which bundled with Spring 3.2.4.
May I know any chance to run Activiti 5.13 with Spring 3.2.4
I configured the dependencies of the Activiti using Spring 3.2.4 instead of 3.1.2, but not luck, I unable to make it work and facing the following error while calling the IdentityService API and attached here is the dependency report:
Error initializing the application: null
at org.activiti.engine.impl.db.DbSqlSession$CheckedDeleteOperation.clearCache(DbSqlSession.j
ava:215)
at org.activiti.engine.impl.db.DbSqlSession.removeUnnecessaryOperations(DbSqlSession.java:46
7)
at org.activiti.engine.impl.db.DbSqlSession.flush(DbSqlSession.java:423)
at org.activiti.engine.impl.interceptor.CommandContext.flushSessions(CommandContext.java:169
at org.activiti.engine.impl.interceptor.CommandContext.close(CommandContext.java:116)
at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInte
rceptor.java:70)
at org.activiti.spring.SpringTransactionInterceptor$1.doInTransaction(SpringTransactionInter
ceptor.java:42)
at org.activiti.spring.SpringTransactionInterceptor.execute(SpringTransactionInterceptor.jav
a:40)
at org.activiti.engine.impl.IdentityServiceImpl.deleteGroup(IdentityServiceImpl.java:91)
at VacationRequestBootStrap$_createUsersAndGroups_closure3.doCall(VacationRequestBootStrap.g
roovy:50)
at VacationRequestBootStrap.createUsersAndGroups(VacationRequestBootStrap.groovy:49)
at VacationRequestBootStrap$_closure1_closure4_closure6.doCall(VacationRequestBootStrap.groo
vy:41)
at grails.util.Environment$EnvironmentBlockEvaluator.execute(Environment.java:321)
at grails.util.Environment.executeForEnvironment(Environment.java:302)
at grails.util.Environment.executeForCurrentEnvironment(Environment.java:277)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
schema export unsuccessful
org.h2.jdbc.JdbcSQLException: Database is already closed (to disable automatic closing at VM shutdow
n, add ";DB_CLOSE_ON_EXIT=FALSE" to the db URL) [90121-170]
at org.h2.message.DbException.getJdbcSQLException(DbException.java:329)
at org.h2.message.DbException.get(DbException.java:169)
at org.h2.message.DbException.get(DbException.java:146)
at org.h2.message.DbException.get(DbException.java:135)
at org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1391)
at org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1366)
at org.h2.jdbc.JdbcConnection.getAutoCommit(JdbcConnection.java:424)
Best regards,
Chee Kin
