Problems starting Alfresco
thomas91
I've started alfresco after installing:
smitty-op:/opt/alfresco # ./alfresco.sh start
Using CATALINA_BASE:   /opt/alfresco/tomcat
Using CATALINA_HOME:   /opt/alfresco/tomcat
Using CATALINA_TMPDIR: /opt/alfresco/tomcat/temp
Using JRE_HOME:       /opt/jdk1.6.0_07/
Does this look like a correct start of alfresco? At least there are no error messages.
But if I browse to http://localhost:8080/alfresco (I used the IP instead of localhost, since I've tried it from outside the server) the side isn't displayed (message: "Although the side seems to be valid no connection could be established") . Now I'm not sure if Alfresco/Tomcart isn't started correctly or if it is a network/firewall problem.
Thomas
11 REPLIES 11
zaizi
So you already have a java process running that is bound to that port. Look up details of the process by "ps -p 27182". 27182 is the PID number from your previous command.
thomas91
I think  killing the java process solved this problem, but I have now problems with the postgresql-db:
09:58:26,876 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'usageQuotaProtector' defined in class path resource [alfresco/usage-services-context.xml]: Invocation of init method failed; nested exception is org.springframework.transaction.CannotCreateTransactionException: Could not open Hibernate Session for transaction; nested exception is org.hibernate.exception.GenericJDBCException: Cannot open connection
Caused by: org.springframework.transaction.CannotCreateTransactionException: Could not open Hibernate Session for transaction; nested exception is org.hibernate.exception.GenericJDBCException: Cannot open connection
Caused by: org.hibernate.exception.GenericJDBCException: Cannot open connection
        at org.hibernate.exception.SQLStateConverter.handledNonSpecificException(SQLStateConverter.java:103)
        at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:91)
        at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:43)
        at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:29)
        at org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:420)
        at org.hibernate.jdbc.ConnectionManager.getConnection(ConnectionManager.java:144)
        at org.hibernate.jdbc.JDBCContext.connection(JDBCContext.java:119)
        at org.hibernate.transaction.JDBCTransaction.begin(JDBCTransaction.java:57)
        at org.hibernate.impl.SessionImpl.beginTransaction(SessionImpl.java:1326)
        at org.springframework.orm.hibernate3.HibernateTransactionManager.doBegin(HibernateTransactionManager.java:497)
        at org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:349)
        at org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:255)
        at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:102)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:176)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:210)
        at $Proxy62.getEnabled(Unknown Source)
        at org.alfresco.repo.usage.UsageQuotaProtector.init(UsageQuotaProtector.java:78)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1160)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1122)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1085)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:429)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:247)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:161)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:273)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:346)
Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (FATAL: Ident-Authentifizierung f��r Benutzer ��alfresco�� fehlgeschlagen)
        at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:855)
        at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:540)
        at org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:81)
        at org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:417)
        … 54 more
Caused by: org.postgresql.util.PSQLException: FATAL: Ident-Authentifizierung f��r Benutzer ��alfresco�� fehlgeschlagen
        at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:276)
        at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:95)
        at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:66)
        at org.postgresql.jdbc2.AbstractJdbc2Connection.<init>(AbstractJdbc2Connection.java:124)
        at org.postgresql.jdbc3.AbstractJdbc3Connection.<init>(AbstractJdbc3Connection.java:30)
        at org.postgresql.jdbc4.AbstractJdbc4Connection.<init>(AbstractJdbc4Connection.java:29)
        at org.postgresql.jdbc4.Jdbc4Connection.<init>(Jdbc4Connection.java:24)
        at org.postgresql.Driver.makeConnection(Driver.java:386)
        at org.postgresql.Driver.connect(Driver.java:260)
        at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:37)
        at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:290)
        at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:877)
        at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:851)
        … 57 more
09:58:26,882 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco]] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
my entries in /var/lib/pgsql/data/pg_hba.conf (I use PostgreSQL 8.1.9)
# TYPE  DATABASE    USER        CIDR-ADDRESS          METHOD
# "local" is for Unix domain socket connections only
local   all         all                               ident sameuser
# IPv4 local connections:
host    all         all         127.0.0.1/32          password
# IPv6 local connections:
host    all         all         ::1/128               ident sameuser
