Problem with Alfresco 3.2 Community running on Win 2008
bobbi
I installed Alfresco 3.2 Community on Windows 2008 full version.  I did not install mySQL because I need to use a MS SQL server.  I pointed the properties file to the MSSQL server, made sure the set db.driver=net.sourceforge.jtds.jdbc.Driver and made sure the hibernate stuff is all in place.  When I start Alfresco I keep getting a 404 error and this error in the log file.  Any help with this would be much appreciated.  Thanks
Bobbi
ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexRecoveryBootstrap' defined in class path resource [alfresco/bootstrap-context.xml]: Cannot resolve reference to bean 'indexRecoveryComponent' while setting bean property 'indexRecoveryComponent'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexRecoveryComponent' defined in class path resource [alfresco/index-recovery-context.xml]: Error setting property values; nested exception is org.springframework.beans.PropertyBatchUpdateException; nested PropertyAccessExceptions (1) are:
PropertyAccessException 1: org.springframework.beans.MethodInvocationException: Property 'recoveryMode' threw exception; nested exception is java.lang.IllegalArgumentException: No enum const class org.alfresco.repo.node.index.FullIndexRecoveryComponent$RecoveryMode.Auto
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexRecoveryComponent' defined in class path resource [alfresco/index-recovery-context.xml]: Error setting property values; nested exception is org.springframework.beans.PropertyBatchUpdateException; nested PropertyAccessExceptions (1) are:
Caused by: org.springframework.beans.PropertyBatchUpdateException; nested PropertyAccessException details (1) are:
Caused by: java.lang.IllegalArgumentException: No enum const class org.alfresco.repo.node.index.FullIndexRecoveryComponent$RecoveryMode.Auto
   at java.lang.Enum.valueOf(Enum.java:196)
   at org.alfresco.repo.node.index.FullIndexRecoveryComponent$RecoveryMode.valueOf(FullIndexRecoveryComponent.java:69)
   at org.alfresco.repo.node.index.FullIndexRecoveryComponent.setRecoveryMode(FullIndexRecoveryComponent.java:121)
   at org.springframework.beans.BeanWrapperImpl.setPropertyValue(BeanWrapperImpl.java:821)
   at org.springframework.beans.BeanWrapperImpl.setPropertyValue(BeanWrapperImpl.java:645)
   at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:78)
   at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:59)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1127)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:862)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:423)
   at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:249)
   at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:155)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:246)
   at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:160)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:267)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:110)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1100)
   at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:248)
   at org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:820)
   at org.springframework.context.support.AbstractApplicationContext.registerListeners(AbstractApplicationContext.java:597)
10:40:53,445 INFO  [org.alfresco.config.JBossEnabledWebApplicationContext] Refreshing org.alfresco.config.JBossEnabledWebApplicationContext@17485ac: display name [Root WebApplicationContext]; startup date [Mon May 10 10:40:53 PDT 2010]; root of context hierarchy
10:40:53,617 INFO  [org.alfresco.config.JBossEnabledWebApplicationContext] Bean factory for application context [org.alfresco.config.JBossEnabledWebApplicationContext@17485ac]: org.springframework.beans.factory.support.DefaultListableBeanFactory@4ab70a
10:40:54,289 INFO  [org.alfresco.web.scripts.DeclarativeRegistry] Registered 24 Web Scripts (+0 failed), 26 URLs
10:40:54,304 INFO  [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 158.24347ms)
10:40:54,367 INFO  [org.alfresco.web.scripts.DeclarativeRegistry] Registered 42 Web Scripts (+0 failed), 44 URLs
10:40:54,382 INFO  [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 83.889366ms)
10:40:54,414 INFO  [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
4 REPLIES 4
mrogers
RecoveryMode is case sensitive.   Try AUTO.
bobbi
That did it, thanks.
bobbi
Now I'm getting the following error.  Anyone ever seen this?
11:21:06,414 ERROR [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema auto-update failed
org.alfresco.error.AlfrescoRuntimeException: 04100000 The schema script could not be found at location classpath:alfresco/dbscripts/create/3.2/${db.script.dialect}/AlfrescoPostCreate-3.2-LockTables.sql
   at org.alfresco.error.AlfrescoRuntimeException.create(AlfrescoRuntimeException.java:49)
   at org.alfresco.repo.domain.schema.SchemaBootstrap.executeScriptUrl(SchemaBootstrap.java:824)
   at org.alfresco.repo.domain.schema.SchemaBootstrap.updateSchema(SchemaBootstrap.java:706)
   at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBootstrap.java:1238)
   at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:617)
bobbi
Needed to set index.recovery.mode=FULL in the repository.properties file.
Now I'm getting this ugly error.  Anyone ever seen this or know how to get past it?
org.alfresco.error.AlfrescoRuntimeException: 04100040 Bootstrap failed
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:352)
   at org.alfresco.repo.importer.ImporterBootstrap.onBootstrap(ImporterBootstrap.java:709)
Caused by: org.alfresco.service.cmr.view.ImporterException: Failed to import package at line 24; column 19 due to error: 04100039 Failed to set content property on stream closure:
   node: system://system/a83656bb-7b12-49a6-a7c9-dc783c4dd332
   property: {http://www.alfresco.org/model/system/1.0}versionProperties
   writer: ContentAccessor[ contentUrl=store://2010/5/10/11/51/46df5e69-e575-471c-95d3-9649d2fb3d7b.bin, mimetype=text/plain, size=259, encoding=UTF8, locale=en_US]
   at org.alfresco.repo.importer.view.ViewParser.parse(ViewParser.java:196)
   at org.alfresco.repo.importer.ImporterComponent.parserImport(ImporterComponent.java:359)
   at org.alfresco.repo.importer.ImporterComponent.importView(ImporterComponent.java:223)
   at org.alfresco.repo.importer.ImporterBootstrap.doImport(ImporterBootstrap.java:466)
   at org.alfresco.repo.importer.ImporterBootstrap.access$000(ImporterBootstrap.java:75)
   at org.alfresco.repo.importer.ImporterBootstrap$1$1.execute(ImporterBootstrap.java:341)
   at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:326)
   at org.alfresco.repo.importer.ImporterBootstrap$1.doWork(ImporterBootstrap.java:345)
   at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:489)
   at org.alfresco.repo.importer.ImporterBootstrap.bootstrap(ImporterBootstrap.java:348)
   … 36 more
