CIFS not starting issue
dantella
I havent come across this issue during my searches. Running community 2.1 on a Win2k3 virtual machine joined to a domain. I finally got NTLM passthru working and i thought CIFS setup. I also got the LDAP sync working for my domain.
I've copied the win32netbios.dll to a valid path, SYSTEM32. I can startup Alfresco, and get no errors, I can login through the webclient, and all my users are imported just fine.
FTP works fine with NTLM auth, and its using a SQL Server 2005 backend….
the CIFS server doesnt seem to be starting, and I'm not getting any errors at all. nbtstat -n doesnt show the _A server name being presented.
Any Ideas?
David
File-Servers.xml is like this:
__________________________
<alfresco-config area="file-servers">
   <config evaluator="string-compare" condition="CIFS Server">
      <serverEnable enabled="true"/>
      <comment>Alfresco CIFS Server</comment>
      <host name="Alfresco21" domain="xxxx"/>
      <host name="${localname}_A"/>
      <!– Set to the broadcast mask for the subnet –>
      <broadcast>255.255.255.255</broadcast>
      <!– Use Java socket based NetBIOS over TCP/IP and native SMB on linux –>
      <tcpipSMB platforms="linux,solaris,macosx"/>
      <netBIOSSMB platforms="linux,solaris,macosx"/>
      <!– Can be mapped to non-privileged ports, then use firewall rules to forward
          requests from the standard ports –>
      <tcpipSMB port="1445" platforms="linux,solaris,macosx"/>
      <netBIOSSMB sessionPort="1139" namePort="1137" datagramPort="1138" platforms="linux,solaris,macosx"/>
      <hostAnnounce interval="5"/>
      <!– Use Win32 NetBIOS interface on Windows –>
      <Win32NetBIOS api="winsock"/>
      <Win32Announce interval="5"/>
      <WINS>
         <primary>192.168.10.100</primary>
         <!– <secondary>5.6.7.8</secondary> –>
      </WINS>
      <sessionDebug flags="Negotiate,Socket"/>
   </config>
      <!–      <debug flags="File,Search,Error,Directory,Info,DataPort"/> –>
   </config>
   <config evaluator="string-compare" condition="NFS Server">
      <serverEnable enabled="false"/>
   </config>
   <config evaluator="string-compare" condition="Filesystems">
      <filesystems>
         <!– Alfresco repository access shared filesystem –>
         <filesystem name="Alfresco">
            <store>workspace://SpacesStore</store>
            <rootPath>/app:company_home</rootPath>
            <!– Add a URL file to each folder that links back to the web client –>
            <urlFile>
               <filename>__AlfrescoClient.url</filename>
               <webpath>http://${localname}:8080/alfresco/</webpath>
            </urlFile>
            <!– Mark locked files as offline –>
            <offlineFiles/>
            <!– Desktop actions –>
            <!– Uses a client-side application to trigger a server-side action                         –>
            <!–   Echo - displays a message echoed from the server                                     –>
            <!–   URL  - launches a URL via the Windows shell                                          –>
            <!–   CmdLine - launches the Notepad application                                           –>
            <!–   CheckInOut - checks files in/out, drag and drop files onto the application           –>
            <!–   JavaScript - run a server-side script                                                –>
            <!–   JavaScriptURL - server-side script that generates a URL to the folder using a ticket –>
            <!–                   to avoid having to logon                                             –>
            <desktopActions>
               <global>
                  <path>alfresco/desktop/Alfresco.exe</path>
               </global>
               <action>
                  <class>org.alfresco.filesys.smb.server.repo.desk.EchoDesktopAction</class>
                  <name>Echo</name>
                  <filename>__AlfrescoEcho.exe</filename>
               </action>
               <action>
                  <class>org.alfresco.filesys.smb.server.repo.desk.URLDesktopAction</class>
                  <name>URL</name>
                  <filename>__AlfrescoURL.exe</filename>
               </action>
               <action>
                  <class>org.alfresco.filesys.smb.server.repo.desk.CmdLineDesktopAction</class>
                  <name>CmdLine</name>
                  <filename>__AlfrescoCmd.exe</filename>
               </action>
               <action>
                  <class>org.alfresco.filesys.smb.server.repo.desk.CheckInOutDesktopAction</class>
                  <name>CheckInOut</name>
                  <filename>__AlfrescoCheckInOut.exe</filename>
               </action>
               <action>
                  <class>org.alfresco.filesys.smb.server.repo.desk.JavaScriptDesktopAction</class>
                  <name>JavaScript</name>
                  <filename>__AlfrescoScript.exe</filename>
                  <script>alfresco/desktop/dumpRequest.js</script>
                  <attributes>anyFiles, multiplePaths , allowNoParams</attributes>
                  <preprocess>confirm, copyToTarget</preprocess>
               </action>
               <action>
                  <name>JavaScriptURL</name>
                  <filename>__AlfrescoDetails.exe</filename>
                  <script>alfresco/desktop/showDetails.js</script>
                  <attributes>anyFiles</attributes>
                  <preprocess>copyToTarget</preprocess>
               </action>
            </desktopActions>
            <accessControl default="Write">
               <user name="admin" access="Write"/>
               <address subnet="90.1.0.0" mask="255.255.0.0" access="Write"/>
            </accessControl>
         </filesystem>
         <!– AVM virtualization view of all stores/versions for WCM –>
         <avmfilesystem name="AVM">
            <virtualView/>
         </avmfilesystem>
      </filesystems>
   </config>
      <authenticator type="enterprise">
      </authenticator>
      <globalAccessControl default="None">
         <address ip="90.1.0.90" access="Write"/>
      </globalAccessControl>
      <users>
         <localuser name="user">
            <password>user</password>
            <comment>Normal user account</comment>
         </localuser>
         <localuser name="administrator">
            <password>admin</password>
            <administrator/>
            <comment>Administrator account</comment>
         </localuser>
      </users>
   </config>
</alfresco-config>
11 REPLIES 11
dantella
Q, I will post both… I didnt edit anything in the War file:
File-Servers-Custom.xml
______________________________
   <!– To override the default Alfresco filesystem use replace="true", to –>
   <!– add additional filesystems remove the replace="true" attribute     –>
    <serverEnable enabled="true" />
    <!– Insert here IP or hostname of this alfresco server, and the NT domain name in which you want to integrate–>
    <host name="Alfresco21_A" domain="xxxx" />
    <sessionDebug flags="Negotiate,Socket" />
  </config>
   <config evaluator="string-compare" condition="Filesystems" replace="true">
      <filesystems>
            <urlFile>
               <filename>__Alfresco.url</filename>
            </urlFile>
            <offlineFiles/>
            <desktopActions>
               <global>
               </global>
               <action>
                  <filename>__CheckInOut.exe</filename>
               </action>
               <action>
                  <filename>__ShowDetails.exe</filename>
               </action>
            </desktopActions>
            </accessControl>
         </filesystem>
            <virtualView/>
         </avmfilesystem>
      </filesystems>
   </config>
  <!– Authenticator should be of type alfresco –>
  <config evaluator="string-compare" condition="Filesystem Security" replace="true">
    <authenticator type="alfresco" />
  </config>
</alfresco-config>
dantella
File-Servers.xml
      <WINS>
      </WINS>
   </config>
   </config>
   </config>
     <filesystems>
         <urlFile>
            </urlFile>
          <offlineFiles/>
         <desktopActions>
            <global>
            </global>
            <action>
               <name>Echo</name>
            </action>
            <action>
               <name>URL</name>
            </action>
            <action>
            </action>
            <action>
            </action>
            <action>
            </action>
            <action>
            </action>
         </desktopActions>
            </accessControl>
         </filesystem>
            <virtualView/>
         </avmfilesystem>
      </filesystems>
   </config>
      </authenticator>
      <users>
         </localuser>
            <administrator/>
         </localuser>
      </users>
   </config>
</alfresco-config>
