CIFS and WebDAV Problems with Mac OS X 10.4.3
alex
I installed Alfresco on my MacOS X Tiger machine and the server works very well, but I have problems when using the OS X Finder to connect to the CIFS server.
I can connect fine and everything works well until I want to access a Share that contains more than nine sub-shares. As soon as I open a share with more than 9 sub-shares I get disconnected from the CIFS server with the following log entry:
16:27:55,163 ERROR [org.alfresco.smb.protocol] Closing session due to exception
java.lang.UnsupportedOperationException
        at org.alfresco.filesys.smb.server.repo.ContentSearchContext.restartAt(ContentSearchContext.java:152)
        at org.alfresco.filesys.smb.server.NTProtocolHandler.procTrans2FindFirst(NTProtocolHandler.java:3484)
        at org.alfresco.filesys.smb.server.NTProtocolHandler.processTransactionBuffer(NTProtocolHandler.java:1987)
        at org.alfresco.filesys.smb.server.NTProtocolHandler.procTransact2(NTProtocolHandler.java:1824)
        at org.alfresco.filesys.smb.server.NTProtocolHandler.runProtocol(NTProtocolHandler.java:226)
        at org.alfresco.filesys.smb.server.SMBSrvSession.runHandler(SMBSrvSession.java:1657)
        at org.alfresco.filesys.smb.server.SMBSrvSession.run(SMBSrvSession.java:1554)
        at java.lang.Thread.run(Thread.java:613)
(This is with the default sessionDebug flags line from the file-servers.xml uncommented and debug enabled in the log4j.properties - there are no debug messages for this operation. Which other sessionDebug flags can I add to get more detail?)
If I am using the Samba smbclient command-line utility that comes with OS X I do not encounter such problems.
Another problem is WebDAV using the WebDAV client built into Finder: It simply doesn't work. If I say "Connect to server…" and enter "http://localhost:8080/alfresco/webdav" as URL and hit the Connect button the "Connecting…" window pops up for a second or two and then silently disappears - no trace in the Alfresco log, no error message, nothing. This does not seem a problem of my configuration, btw, because exactly the same thing happens when I try to connect to the official Alfresco demo installation.
alex
If I access Alfresco with the OS X Finder WebDAV client the Tomcat access log only gets the following entry:
0:0:0:0:0:0:0:1%0 - - [22/Jan/2006:23:07:35 +0100] "OPTIONS /alfresco/webdav/ HTTP/1.1" 401 -
That's when the Finder "Connecting…" dialog simply disappears.
