AuthorityService: problem removing an authority group
sergio
Hi.
It is not totally clear to me how to create and delete a GROUP (authority group) using the AuthorityService Java class.
Creating a GROUP using the createAuthority(AuthorityType.GROUP,parentGroupName,groupName) method works: a new GROUP is created and visibile into Alfresco.
Deleting a GROUP using the deleteAuthority(groupName) seems not to work as I thought. The group previously created using the createAuthority() method still remains in the repository as is visibile in the web administration console. Why? Maybe the procedure of deleting a GROUP is different and more complex?
Taking a look at another prevoius post
http://forums.alfresco.com/viewtopic.php?t=8327&highlight=authorityservice+deleteauthority
Andy says that "The authority is deleted via the node serivce", but what does it mean exactly? Should I delete a GROUP authority using the nodeService instead of the authorityService?
Some clarification will be very appreciated.
All the best,
Sergio
andy
Hi
You should delete the group as described. You need to use the full name of the group - prefixed with GROUP.
Take a look at the tests.
Andy
sergio
Ok Andy, thanks.
Done. It works. Now I have a problem with users, but this will be another story (and post).
See you soon.
