Activiti Engine not picking up properties from activiti.cfg.xml
shil-srini
Hi there,
I'm New to Activiti and Started with the local deployment of activiti after downloading the source. I'm trying out a simple task where a mail can be sent on some condition. I've changed the activiti.cfg.xml in activiti-engine\src\test\resources, It is still taking the default java mail configuration and throwing an error stating mail cannot be sent to localhost port 25.
I've made the following changes in the file activiti-engine\src\test\resources\activiti.cfg.xml:
<bean id="processEngineConfiguration"
    class="org.activiti.engine.impl.cfg.StandaloneProcessEngineConfiguration">
    <property name="mailServerHost" value="smtp.gmail.com" />
         <property name="mailServerPort" value="587" />
         <property name="mailServerDefaultFrom" value="[email protected]" />
         <property name="mailServerUsername" value="[email protected]" />
         <property name="mailServerPassword" value="******" />
          <property name="mailServerUseTLS" value="true" />
          <property name="history" value="full" />
</bean>
I've found a workaround where I modify the engine.properties for mail server settings and the changes are reflected. Though the mailserver changes are reflecting there I'm facing an issue where the useTLS property cannot be set there. Smiley Sad
Could anybody please help?
Thanks.
4 REPLIES 4
shil-srini
The properties added:
<blockcode>
<blockcode>
jbarrez
that looks allright. And you say it's still using port 25? You are sure this config is picked up?
shil-srini
No. The configuration is not being picked up. That's the problem. I changed the configuration, built and deployed it on server again.
But the port value and host does not seem to change. Is there anything else I'm missing out?
jbarrez
How can you be sure? Did you for example change the db properties to make bootup fail?
The properties you pasted above are correct from the looks of it.
Where is the config file placed?
